Junction Box For Electric Range - Electrical - DIY Chatroom Home Improvement Forum
Old 06-13-2012, 01:49 PM   #1
Junction Box for electric range
Hello,
I am in the process of a kitchen renovation. I want to move the electric range to a different location. It is wired with #8 3 wire cable.
The current cable is about 2 feet too short to reach the new location.
I can change the cable; however, it occurs to me that a junction box would allow me to simply extend the existing wiring to the new location.
In the new arrangement, the junction box would remain accessible but would reside behind the fridge out of sight.
My question is: Is a junction box in this scenario within code?
MacIsaac is offline   Reply With Quote
Old 06-13-2012, 01:57 PM   #2
Licensed electrician
Rewards Points: 1,024
If you only have 3 conductors in the cable it should be changed to a 4 wire cable.
Old 06-13-2012, 02:03 PM   #3
Sorry, It is 3 wire plus ground which is , I suspect, your definition of 4 wire
Old 06-13-2012, 02:06 PM   #4
With a 3 wire plus ground you can extend the circuit using proper connectors in a properly sized permanently accessible junction box.
Old 06-13-2012, 02:09 PM   #5
Code05's Avatar
Rewards Points: 1,104
Say it was a 3W circuit, can I move it?
Code05 is offline   Reply With Quote
Old 06-13-2012, 02:13 PM   #6
Shorter or longer?
Old 06-13-2012, 02:14 PM   #7
Rewards Points: 776
Originally Posted by MacIsaac View Post
Hello,
Is the panel in the basement and readily accessible (unfinished or drop ceiling in basement) to the new range location? Is it a relatively short run? If so why not run a new line to the panel and avoid a band-aide extension.
curiousB is offline   Reply With Quote
Old 06-13-2012, 02:18 PM   #8
Code05's Avatar
Shorter or longer?
The word "extension" is what you are referring to I am guessing?
Old 06-13-2012, 02:20 PM   #9
Code05's Avatar
Er, why is a proper and legal splice a band-aid extension?
The Following User Says Thank You to Code05 For This Useful Post:
k_buz (06-13-2012)
Old 06-13-2012, 02:32 PM   #10
That would be one point of contention. Although the reality is if the 3 wire was safe enough to continue in use as is what would be the harm in extending the circuit? It does not get any more dangerous 5 foot longer than it was.
Old 06-13-2012, 02:39 PM   #11
Code05's Avatar
Yeah, that was my point, tough call IMO. Did you know that there was very little substantiation for the code change?
Old 06-13-2012, 08:58 PM   #12
To Clarify as best I can:
The current distance is about 35 feet.
So, I am looking at a new cable at say 38 feet.
Yes, I have ready access to the main breaker panel.
Yes, I can run a new cable.
In my area of the world, junction boxes are allowed provided they remain accessable. However, the code is silent on how heavy a wire can be spliced using a junction box. I get a bit nervous when the amperage gets up to 40 and the voltage is 240. In the short term, I am sure that it will work but time and corrosion can take a toll. So I would rather be safe with a little less cash than sorry some time later.
Thanks Fellows.
MacIsaac
Old 06-13-2012, 09:19 PM   #13
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
In reality its worked for years, but it only takes a small fraction to deem it unsafe... one incident could change everything.
Old 06-14-2012, 11:24 AM   #14
To my knowledge there isn't a limit based on wire size on what can and can't be spliced. Provided of course that a listed and code approve mechanism for performing the splice exists.
So yes, you can splice your range line provided that you follow the rules for performing the splice. Proper connectors, accessible box, proper fill percentage, proper cable type, no knob and tube, etc.
If there is a relevant code section prohibiting what you want to do, it takes precedence. But based solely on size, no problem.
Evstarr is offline   Reply With Quote
Old 06-14-2012, 12:06 PM   #15
Code05's Avatar
From MH, I assume you know who Don is.
The change to delete the 3 wire circuit and require the 4 wire one took at least 5 code cycles. In all of the proposals and comments, there was not one documented case of a shock or other problem caused by the use of a 3 wire circuit.
Don
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 02:33 AM
Drop in range versus self standing for narrow area sbrink Kitchen & Bath Remodeling 6 01-21-2011 11:17 AM
Moving Electric Range Plug dmartins Electrical 3 11-23-2010 08:48 AM
Had a new electric range installed in my apartment - does this sound right? SAABturboDRIVR Electrical 15 01-02-2010 06:39 AM
Range & Junction Box Distance G3Aloha Electrical 1 05-10-2008 01:13 PM
