Junction Box For Detatched Garage Feeder - Electrical - DIY Chatroom Home Improvement Forum
Old 06-08-2011, 01:47 PM   #1
I ask the impossible!
Rewards Points: 660
Junction box for detatched garage feeder
Hopefully only a brief explanation is needed, so here's the background in brief (a lot more detail can be found in other recent posts I've made)
I am running 100 amp service to my garage, I am using 1/0 aluminum conductors for the feeder. This is running underground in 2" rigid metal conduit. Also in this conduit is 14 ga. THWN for a 3-way switch. Thus, at each end, there is an 8x8 junction box. I also have a #8 solid copper ground wire inside the conduit. It may be overkill, but I have EMT from the junction box to the panel and thus I have both a ground wire AND a continuous metal conduit that can act as the ground conductor.
Because my inspector had issues for which the resolution involved moving the panel in the house, and the garage feeders were connected at the time, my wires ended up too short. I made splices in the house-side junction box. I chose split-bolt connectors because I needed to economize and $4 connectors x3 works out to less than $15 polaris connectors x3.
(As a side note, if polaris connectors avoid the taping process, the cost difference might not have been so big as it seemed. I used about 2/3 of a roll of rubber mastic tape per split bolt, so $18 of rubber mastic tape was needed for all 3 connections. Plus the cost of the vinyl tape, but I don't count that since I already had that on hand.)
I followed 3M's procedure for taping split-bolt connections which is illustrated in the following video:
The end result can be seen in the attached photo, please if you see anything that is in need of correction I would appreciate it being pointed out.
For the first time I powered up the garage subpanel and turned on a breaker for the only outlet I've connected so I can test everything - a dedicated circuit for an outlet to run the GDO. Everything worked and an outlet checker lighted up good.
And for those following my ongoing saga, I moved back my inspecton to Friday. This was the last thing I needed (and I probably would've had this done last night if I was not so tired, not to mention all the job phone calls I've gotten this morning) Tommorrow afternoon I've got 2 job interviews... I suppose it's good to be busy this way, but it makes it challenging to get projects done.
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Weatherproofing garage help Perfik Building & Construction 2 10-17-2012 03:30 PM
Restoring power to detached garage alexmce Electrical 4 05-31-2011 05:27 PM
Can garage feeder be spliced to SE once inside? WillK Electrical 5 05-27-2011 07:02 AM
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 03:56 PM
Garage Ideas? tripflex General DIY Discussions 13 12-16-2009 07:06 PM
