Junction Box Cover - Electrical - DIY Chatroom Home Improvement Forum
Old 02-25-2008, 06:51 PM   #1
electrical contractor
Rewards Points: 150
Junction box cover
Hi everyone, just wondering has any one else seen the stamp on 4x4 junction box lids? The stamp says "underside". What is it there for?
Jimmy
Life is tough, Life is tougher when you are stupid.
wire_twister is offline   Reply With Quote
Old 02-25-2008, 07:31 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
That's a new one to me.
Old 02-25-2008, 07:34 PM   #3
Building and plumbing
USP45's Avatar
Rewards Points: 150
Not sure either, as long as the lid is metal, should be fine either way
USP45 is offline   Reply With Quote
Old 02-25-2008, 07:37 PM   #4
Licensed Pro
Tightening the screw pulls the lid toward the narrow part of the screw slot.
Old 02-25-2008, 07:39 PM   #5
" Euro " electrician
frenchelectrican's Avatar
I did see couple of them starting to crop up a bit.,,
anyway if that box cover do have a raised dimple it will useally tell which way it is out.
I Know the RACO did have that on the marking on it but i dont know about other manufacaters did that route as well.
Merci, Marc
P.S. i dont have much luck finding a photo relateing to this topic
Old 02-25-2008, 08:08 PM   #6
Rewards Points: 266
Interesting thread. I've wondered the same thing.
I had such a cover lying on my work bench.... I snapped a few pics.
Nothing real special about it....
junkcollector is offline   Reply With Quote
Old 02-25-2008, 08:25 PM   #7
That's IT!
Old 02-25-2008, 10:16 PM   #8
Electrician
I always install a blank plate so it wouldn't fall from gravity if the screws were loosened... o'well...
chris75 is offline   Reply With Quote
Old 02-26-2008, 05:31 AM   #9
You can do that in either case. Even if you put that "under side" mark toward the box, and the cover wants to fall off, just roll the cover 180 deg. Or even 90 deg in some cases.
Old 02-26-2008, 05:33 AM   #10
When is fishing season?
CowboyAndy's Avatar
I have seen the ones that say "underside" as well, I always make sure they are on the underside!
Side note: Do the pros label jboxes, as in write with marker on the outside of the cover what the wires are that are inside it? I have made it a habit to mark them.
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 02-26-2008, 04:43 PM   #11
The good ones do. Panel and circuit numbers
220/221 is offline   Reply With Quote
Old 02-27-2008, 05:42 AM   #12
CowboyAndy's Avatar
220/221, when you say PANEL and circuit #s, what do you mean by PANEL?
MY HOUSE OWNS ME!
Old 02-27-2008, 06:16 AM   #13
Rewards Points: 150
Panel number for a house/condo/apartment with more than one panel.
Jimmy
Old 02-27-2008, 06:25 AM   #14
CowboyAndy's Avatar
Gotcha!
MY HOUSE OWNS ME!
Old 02-27-2008, 09:37 AM   #15
joed's Avatar
Rewards Points: 13,354
If the box is on the ceiling does the underside marking go on the outside of the box?
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 07:34 PM
Weatherproof Cover Plates Al the Diy guy Electrical 7 02-10-2008 10:38 AM
Cover for Whole House Fan ntfspark General DIY Discussions 4 11-18-2007 12:57 AM
Patio cover Jackhammer Building & Construction 3 07-10-2007 03:49 PM
