Old 09-20-2009, 02:39 AM   #1
Junction box in cabinet - how to mount?
Found some info using the search, but not finding the answer to my specific question...
Putting in kitchen cabinet, and a receptacle above the cabinet/countertop. Using where the existing wire ended, necessitating a junction box. Junction box obviously needs to be accessible.
So what is the best way to mount this j-box? I assume mounting to the cabinet itself is incorrect.
Should I simply mount the box to the wall and cut an appropriately sized access hole in the back of the cabinet, or mount the box to the wall and make up the difference beween wall and cabinet back with an extension ring? Or is either of those two solutions appropriate?
j. pierce is offline   Reply With Quote
Old 09-20-2009, 02:46 AM   #2
GetYourShineBox's Avatar
question is kind of confusing. are you trying to put a receptacle inside the cabinet or mount it on the outside of the cabinet underneath above the counter space?
GetYourShineBox is offline   Reply With Quote
Old 09-20-2009, 05:23 AM   #3
sorry -
would like to put a new receptacle above the countertop. There is an existing wiring run to behind where the cabinet will be mounted (that originally ran to an old and since removed wall-mount heater)
Since this wiring run is in good condition and is not easily removed, I'd like to simply extend this wiring to the new receptacle, by making attaching new wires inside a junction box with a blank plate located at the end of the current wire run.
Since this cabinet is to be a permanent installation, I need to make this junction box accessible; it is this junction box that will be located in the cabinet that I'm curious about the mounting of; I'm fine with the mounting of the new junction box for the outlet.
I'm just wondering if there is a preference for mounting the junction box in the cabinet for extending the wiring, whether an access hole in the back of the cabinet or an extension ring to make the blank plate of the junction box flush with the cabinet is preferred. There will be no outlet in this junction box.
Old 09-20-2009, 07:59 AM   #4
Go ahead with the (usually plastic) extension ring so the junction box cover can fit right on the back of the cabinet. You may need to use two rings to fill the space between the cabinet back and the junction box rim.
Actually it's your preference whether to put the box cover on the wall itself and just have a hole in the back of the cabinet.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 09-20-2009, 11:39 AM   #5
J. V.'s Avatar
Like Allan said, they make special extension rings just for this purpose. They are very common. Just ask at the supply house. They have them at the box stores, but the attendant will most likely have no idea what you are talking about.
Wall Mount Server Cabinet. How much power? cochise7969 Electrical 17 08-17-2009 02:36 PM
hanging 9" kitchen cabinet (wall) and hit air duct, no stud phunam04 Building & Construction 4 06-16-2009 11:08 PM
Oven - junction box in cabinet DIYGST Electrical 5 11-13-2008 04:23 PM
