Junction Box Behind Microwave? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-24-2011, 08:31 AM   #1
Question
Junction Box behind Microwave?
I'm remodeling my kitchen, and replacing/relocating some appliances. To do so, I need to extend an 8 ga circuit. Is it ok to put a junction box inside the cabinet, behind where the microwave will be installed? It's a standard countertop microwave, with a trim kit that will cover the entire enclosure.
The other option would be in the attic directly above the same cabinet.
Is there a preferred approach?
richp0 is offline   Reply With Quote
Old 06-24-2011, 08:44 AM   #2
Rewards Points: 6,652
Only if you can open the cabinet and see the junction box. Otherwise, it is illegal in the scope, due to you have to remove the microwave to get to the junction box. It would be the same as installing a cabinet, and not cutting an access hole where a junction box was placed on the wall. Think of it this way, if there is a problem, how is the next electrician or home owner going to know where to look.
Old 06-24-2011, 09:35 AM   #3
Question
Thanks! I assume there's no issue putting junction box for 8 ga in the attic - correct? Any special considerations for that gauge?
Old 06-24-2011, 09:56 AM   #4
Rewards Points: 1,016
attic is fine as long as accessible.
____________
Vince
Old 06-24-2011, 10:06 AM   #5
Make sure you use the proper connectors to secure the cable where it meets the other going to the new receptacle. BTW, is this Aluminum or Copper #8.
Old 06-24-2011, 10:28 AM   #6
It's copper
Old 06-24-2011, 12:09 PM   #7
Electrical Contractor
jbfan's Avatar
Rewards Points: 534
Is this stove wiring?
Is it 4 conductor?
3 condutor wiring is prohibited from being extended.
jbfan is online now   Reply With Quote
Old 06-24-2011, 12:23 PM   #8
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
The NEC states the following;
314.29 Boxes, Conduit Bodies, and Handhole Enclosures to Be Accessible.
Boxes, conduit bodies, and handhole enclosures shall be installed so that the wiring contained in them can be rendered accessible without removing any part of the building or, in underground circuits, without excavating sidewalks, paving, earth, or other substance that is to be used to establish the finished grade.
A junction box behind the M/W is compliant is long as it is accessible when the M/W is removed. It is no different then the receptacle that the M/W plugs into, or a junction box for a wall mounted oven. The M/W is not part of the building or structure.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 06-24-2011, 12:32 PM   #9
electures, if you have to remove screws to detach the microwave, it is considered a non-compliant use of the junction box. That is why when over the range microwaves are installed, their plugs are up in the cabinet, not directly behind it. If it was a counter-top, or slid into a microwave cabinet above the stove, then yes it is considered removable without having to detach it from the structure.
Old 06-24-2011, 12:53 PM   #10
electures's Avatar
Sorry, you are incorrect. The M/w is not part of the structure. It is an portable appliance.
Old 06-24-2011, 01:03 PM   #11
It's a 3-conductor cable for a cooktop.
As noted earlier, the microwave has a trim kit. The trim kit screws onto brackets, which fasten to the insides of the cabinet.
Old 06-24-2011, 01:04 PM   #12
Again, it is a part of the structure, when it is screwed into the securing rail to hold it over a range, or counter. The rules apply, because you have to remove it from the structure, in order to get behind it. That is why again, they place the outlet for them above in a cabinet, so it can be de-powered in case of incident that may warrant so.
Old 06-24-2011, 01:07 PM   #13
In that case, follow the directions to place the jb up in the attic, or in the cabinet if cut out is able to be made.
Old 06-24-2011, 01:16 PM   #14
What about other comment from jbfan, that "3 condutor wiring is prohibited from being extended". Does that mean that I really need to run a new line from the service entrance?
Old 06-24-2011, 01:43 PM   #15
Full time DIY
According to the CEC/OESC and numerous ESA inspectors, this is correct.
G-Mo is offline   Reply With Quote
over-the-range microwave problem aumanpj Appliances 6 12-04-2010 05:46 PM
Junction boxes for garage T8 fixtures mazeroth Electrical 13 01-25-2010 09:52 PM
HELP. I really need some advice on how to remove an over the range microwave! justmeee Appliances 9 12-24-2009 03:47 AM
Microwave ground prong sparks/melts upon plugging it in microwaveman Electrical 30 05-10-2009 10:30 PM
OTR Microwave installation bfarber Appliances 3 12-22-2008 07:55 PM
