Junction Box In Attic - Electrical - DIY Chatroom Home Improvement Forum
Old 09-05-2011, 02:22 PM   #1
Junction box in attic
Hey all! I installed a junction box in my attic. It is located within 6' of attic access. I understand romex running across the top of the joists needs protection but what about the junction box itself?
I did not install the box on the inside of a joist. So it is not flush or below the joists. I ran a board across the top of two joists and secured the j-box on top of said board. I did it this way b/c I wanted to get the box out of all the blown insulation. So the box is above all joists with the cover facing up. Does this type of installment require additional protection for the box? Like running boards surrounding the box to prevent anything from resting on top of it? Any help is appreciated. Thank you.
mjkiefer is offline   Reply With Quote
Old 09-05-2011, 05:33 PM   #2
Code05's Avatar
Rewards Points: 1,104
Off hand, I would say you are fine. Even if it was a minor violation, I would leave it. Hidden j-boxes are a PITA.
I am assuming that this this is an unfinished attic with limited access. No general storage.
Code05 is offline   Reply With Quote
Old 09-06-2011, 08:45 AM   #3
Code05,
Thanks for your reply. It is an unfinished attic with the only access being in our hall ceiling with no ladder installed.
Old 09-06-2011, 09:28 AM   #4
Code05's Avatar
Originally Posted by mjkiefer View Post
Code05,
You are good IMO.
Accessable attic & Junction boxes (NEC question) IvoryRing Electrical 7 04-10-2013 10:30 AM
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 04:07 PM
Junction box in attic zephed666 Electrical 4 04-28-2011 12:13 PM
Ventilating attic with two roofs senorbungle Building & Construction 2 01-09-2011 05:17 PM
Mounting junction boxes in attic, are both of these locations acceptable? diymonkey Electrical 33 04-09-2009 08:24 AM
