Junction Box - Electrical - DIY Chatroom Home Improvement Forum
Old 03-15-2009, 01:43 PM   #1
Junction Box
I'm installing a junction box with 1 wire coming in and 4 going out. I'm trying to twist and cap 5 wires. Is there a trick to twisting this many wires. Some of the wires seem to loop on the bottom of the twist. As I'm sending this I'm wondering if I just need to strip the wire more. I've attached a picture. See how the white wire looks funny where it meets the red cap
MikeyP is offline   Reply With Quote
Old 03-15-2009, 03:06 PM   #2
Remodeling Contractor
To connect 5 wires strip them longer. Maybe 2 1/2" -3" Line them all up straight with the insulation in the same spot. Now with your klien pliers grab tightly and twist and cut to 1 1/4" length. You could also use a gray wire nut also. If this is not working for you, connect two with a new pigtail and the other two to the other end of this pigtail.
Old 03-15-2009, 03:16 PM   #3
Do not put the box in the wall. Unless you cut a hole in the drywall and install the box in there. Boxes need to be accessible.
rgsgww is offline   Reply With Quote
Old 03-15-2009, 04:34 PM   #4
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
I don't see a ground screw in there
wirenut1110 is offline   Reply With Quote
Old 03-15-2009, 04:45 PM   #5
Looks a little full to me.
I cannot believe I missed that!
Old 03-15-2009, 05:11 PM   #6
Rewards Points: 510
Need crimps or a wire nut on them grounds too
Old 03-15-2009, 05:52 PM   #7
I just assumed he is going to since hes talking about wire nuts.
Old 03-15-2009, 08:05 PM   #8
Thanks guys. The box will be in the attic. It's just hanging down for the picture. Am I missing something with a ground screw. I have 3 boxes for this remodel and all the grounds are wired together with a wire nut but no ground screw. Do I need one and how do I do it?
Old 03-15-2009, 08:09 PM   #9
Is it too full????
Two of the wires are for 2 GFCI plugs I was going to run one into the other but I was told it not to do it that way so I ran one wire per GFCI from this junction box. If there is a way to combine the GFCI plugs I could remove one wire making it less full and easier to wire nut??????
Old 03-15-2009, 08:16 PM   #10
Pick up a couple of ground screws and just pigtail to it. There should be a threaded hole in the box.
Old 03-15-2009, 09:26 PM   #11
I hate this kind of crap. I fix this kind of crap all the time.
Homeowners have no business doing things like this. Too many wires, crappily made up in a too small jbox buried in the attic. You know just enough to be dangerous. Your installation will not last a lifetime. Some poor schmuck will get stuck buying it or fixing it.
Either way, because the clowns are usually long gone by the time I am on the scene repairing their crap work, I am telling you that you are an idiot.
It's not rocket science. I am sure you can get from point A to B, but your work methods are crap. I don't expect you to know how to do it right. This is obviously not your line of work.
I do expect you to know your limitations and hire somebody who can do it right.
If you insist on doing it yourself, take it alla part and use a plastic box, the bigger the better and run all cables in the top to make the wiring more neat. Also, ask yourself, can I eliminate attic Jboxes by making splices in switch/recep boxes?
220/221 is offline   Reply With Quote
Old 03-15-2009, 10:28 PM   #12
haha, i feel the same way, you the ho, should not be doing this,...just looking at your taps makes me cringe....i kinda wish that electrical was like a/c work....they need to stop selling romex to the public!(i know this will never happen), but i can wish
NolaTigaBait is offline   Reply With Quote
Old 03-16-2009, 01:28 AM   #13
Rewards Points: 2,350
I'm not going to rag on the OP, except to say that yes, you need to do a better job.
On a related note, I work in a place where everyone thinks they can do electrical work. And they all do it poorly. Friday, I got a call from a repeat customer. He asked me to come out to his place and talk about his new work building. When I pulled up there was a concrete crew and the plumbers were just finishing up the slab piping. Customer asks me if I can come by and "Certify the wiring" after he gets done with it. I asked him if he was doing the plumbing: "No". How about the concrete: "No". I asked him why. "Because I don't know how to do concrete or plumbing". But you know how to bend pipe and wire this place: "Yep".
So, you can't pour gray mud into a form and you can't figure out how to get the sh*t to flow out of the building, but you have a firm understanding of an invisible, mysterious force of nature that can kill you with a touch: "I reckon so". I got pissed and walked away. It's been a bad month and that just topped it off.
Old 03-16-2009, 08:12 AM   #14
I dont know what tool your using, but you do need to practice twisting.
Maybe your using a needle nose like the diy books say, but that would just give you bad results.
Old 03-16-2009, 08:51 AM   #15
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Originally Posted by MikeyP View Post
Is it too full????
THIS is what I hate! When DIYers get stupid advice from folks who have NO business giving advice!
Let me guess. The guy from Homer Depot?
A packed j-box with one wire to each device box. WHY?????
Sorry, the others have you covered with what to fix.
buried junction box shadango Electrical 28 04-09-2010 05:49 PM
Light Fixture installed-no junction box? AdamsHouseCat Electrical 7 02-02-2009 12:03 PM
Junction box in patio ceiling I_think_I_conduit Electrical 6 08-20-2008 08:28 AM
Junction box calculation mind screw Kingsmurf Electrical 1 07-23-2008 12:33 AM
Junction Question? fw2007 Electrical 10 03-31-2008 12:03 PM
