Junction Box - Electrical - DIY Chatroom Home Improvement Forum
Old 11-12-2012, 06:47 PM   #1
Rewards Points: 528
Junction box
Is there a limit to the number of junction boxes per circuit?
Also with install does positioning have to be in any specific direction or so far apart from another box/outlet ,so long as you can access them?
hidden1 is offline   Reply With Quote
Old 11-12-2012, 06:52 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 246
As many junction boxes as you want, but why use them.
Make all connections inside switch and receptacle locations.
jbfan is online now   Reply With Quote
Old 11-12-2012, 07:06 PM   #3
Rewards Points: 528
Because its in attic.Already were connected.Dont need that many plugs there.
Old 11-12-2012, 07:10 PM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Originally Posted by hidden1 View Post
Because its in attic.Already were spliced .Dont need that many plugs there.
There codes that require receptacles be placed so any point on the wall is not more than 6' from a receptacle.
Old 11-12-2012, 07:33 PM   #5
Rewards Points: 6,652
k_buz, might want to post a sketch, due to some have a hard time trying to picture what the 6 foot rule is.
Old 11-12-2012, 07:40 PM   #6
jrgodwindesigns's Avatar
Remember code also requires junction boxes to be accessible, but if your doing the work your self this would only matter at resale. At resale an inspector will sight any none code electrical which will hurt your effort for full asking price. Finding a good electrician is best.
jrgodwindesigns is offline   Reply With Quote
Old 11-12-2012, 08:03 PM   #7
A Home Inspector will cite if the sun is not at the right angle, or if their dog died that morning. As for the junction boxes, the OP stated they are in the attic, so they meet the criteria of easily accessible.
Old 11-12-2012, 08:18 PM   #8
Rewards Points: 528
is in unfinished attic.11 boxes though..not all on same circuit
Old 11-12-2012, 08:21 PM   #9
You are good to go. Just make sure they are high enough, that if you are blowing in insulation, or mark the spots with a stub of wood, so they can be found later.
You definitely do not want them where people can step on them later, if you blow in insulation that will cover them.
Also to add, I would just forgive the boxes all together, and just pull two lengths of Romex down, so that you have a continuous circuit along the loop, using the boxes where the switches & outlets for the junction points. Figure two romex, six wires, you should be find in the count for fill.
I did that with my last Kitchen circuit, since I am not planning on making any changes with it later on down the road. It uses a little more Romex, but in the long run, it is a whole lot cleaner, and you do not have to go hunting around in insulation, or looking up in a basement joist space when working on the circuit.
Old 11-13-2012, 08:14 AM   #10
Rewards Points: 3,130
Home inspectors are NOT code experts. They will (or should) tell you that up front. Every one I've hired has made me sign a bunch of papers acknowledging that I have read and understand what he is not.
Installing Light on Round Junction Service Box MegR Electrical 7 07-07-2013 09:31 PM
Garage feeder junction box bonding WillK Electrical 0 06-05-2011 11:03 AM
Installing ceiling fixture with a metal junction box Romanuke Electrical 12 03-20-2011 03:37 PM
Junction boxes for garage T8 fixtures mazeroth Electrical 13 01-25-2010 10:52 PM
No Power at Electronic Air Cleaner Junction Box edge10 HVAC 1 09-28-2009 08:26 PM
