-   -   Junction box (http://www.diychatroom.com/f18/junction-box-163122/)
hidden1 11-12-2012 05:47 PM
Junction box
152 Attachment(s)
Is there a limit to the number of junction boxes per circuit?
Also with install does positioning have to be in any specific direction or so far apart from another box/outlet ,so long as you can access them?
jbfan 11-12-2012 05:52 PM
As many junction boxes as you want, but why use them.
Make all connections inside switch and receptacle locations.
hidden1 11-12-2012 06:06 PM
152 Attachment(s)
Because its in attic.Already were connected.Dont need that many plugs there.
k_buz 11-12-2012 06:10 PM
Originally Posted by hidden1 (Post 1050638)
Because its in attic.Already were spliced .Dont need that many plugs there.
There codes that require receptacles be placed so any point on the wall is not more than 6' from a receptacle.
gregzoll 11-12-2012 06:33 PM
k_buz, might want to post a sketch, due to some have a hard time trying to picture what the 6 foot rule is.
jrgodwindesigns 11-12-2012 06:40 PM
Remember code also requires junction boxes to be accessible, but if your doing the work your self this would only matter at resale. At resale an inspector will sight any none code electrical which will hurt your effort for full asking price. Finding a good electrician is best.
gregzoll 11-12-2012 07:03 PM
A Home Inspector will cite if the sun is not at the right angle, or if their dog died that morning. As for the junction boxes, the OP stated they are in the attic, so they meet the criteria of easily accessible.
hidden1 11-12-2012 07:18 PM
152 Attachment(s)
is in unfinished attic.11 boxes though..not all on same circuit
gregzoll 11-12-2012 07:21 PM
You are good to go. Just make sure they are high enough, that if you are blowing in insulation, or mark the spots with a stub of wood, so they can be found later.
You definitely do not want them where people can step on them later, if you blow in insulation that will cover them.
Also to add, I would just forgive the boxes all together, and just pull two lengths of Romex down, so that you have a continuous circuit along the loop, using the boxes where the switches & outlets for the junction points. Figure two romex, six wires, you should be find in the count for fill.
I did that with my last Kitchen circuit, since I am not planning on making any changes with it later on down the road. It uses a little more Romex, but in the long run, it is a whole lot cleaner, and you do not have to go hunting around in insulation, or looking up in a basement joist space when working on the circuit.
md2lgyk 11-13-2012 07:14 AM
Home inspectors are NOT code experts. They will (or should) tell you that up front. Every one I've hired has made me sign a bunch of papers acknowledging that I have read and understand what he is not.
