Junction Box - Electrical - DIY Chatroom Home Improvement Forum
Old 10-28-2012, 11:28 PM   #1
junction box
Hi! I'm wondearin if someone can help me with installation of a new junxtion box?
I have those wires sticking out on the right and I wanted to fish them further to where is the X
my question is:
is it with in the code to run it next to the heating and installing a junction box there? there seemes to be enough room for it
Thank you
wariatka is offline   Reply With Quote
Old 10-29-2012, 12:10 AM   #2
Rewards Points: 12,856
Is that picture right side up?
Can you back up so the guys can see the whole picture?
If it's right side up and that's a window of door opening there's going to be a wood header right there. Plus to get over there you would have to run wires around the duct work.
Is there a ground on those wires?
wariatka (10-29-2012)
Old 10-29-2012, 03:43 AM   #3
the photo is right side up here is another, and yes there is a ground cable
Old 10-29-2012, 05:55 AM   #4
DIY staff
Rewards Points: 7,174
Moving the new J-box next to the heat duct will be within code---go right ahead----
Old 10-29-2012, 09:21 AM   #5
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
The JB can be moved closer to the cold air return. It cannot be installed inside the return. Depending on the framing, that entire area be return. You'll have to look inside the return and if you can see the wire it has to be relocated.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following User Says Thank You to electures For This Useful Post:
Old 10-29-2012, 09:42 AM   #6
Make it easy on yourself and make nice straight cuts with a razor knife along the ceiling to wall area with a razor knife, use a framing square to mark the lines down the wall and mark your spot where it's going to be cut horizontal so cutting the new patch will be a sinch.
I use an ossilating saw for this one, goes through it like butter and will not go so deep it will hit a wire.
Old 10-29-2012, 10:43 PM   #7
thank you
all so much for your help
the celing is concreet thats the problem
and there is space between the duct and drywall
so now I have my work cut out for this weekend
Thank you again
oh yeah im in canada
Temperature in junction box buried under R49 insulation (heat detectors/smoke alarm) darlingm Electrical 2 01-16-2012 04:55 PM
Garage feeder junction box bonding WillK Electrical 0 06-05-2011 11:03 AM
grounding old 2 wire junction to grounded junction gm8075 Electrical 3 03-28-2011 12:46 PM
Installing ceiling fixture with a metal junction box Romanuke Electrical 12 03-20-2011 03:37 PM
Junction boxes for garage T8 fixtures mazeroth Electrical 13 01-25-2010 10:52 PM
