Junction For 12-2 - Electrical - DIY Chatroom Home Improvement Forum
Old 08-03-2011, 12:58 AM   #1
Junction for 12-2
I ran 12-2 wire for a 240 v electric bb heater and ended up having to reposition the heater further away from its original spot. I have more 12-2 so can I put in a junction box and wire nut another 3 feet to the heater? Do I ground to the metal junction box?
Buster
BusterMN is offline   Reply With Quote
Old 08-03-2011, 06:22 AM   #2
Electrician
SD515's Avatar
Rewards Points: 504
Yes and yes. The j-box will have to remain accessible.
Kyle
Old 08-03-2011, 12:19 PM   #3
Rewards Points: 58
Readily accessible means you can open it up anytime you want. You cannot hide it inside the wall. You can put it behind furniture though.
Garage feeder junction box bonding WillK Electrical 0 06-05-2011 11:03 AM
grounding old 2 wire junction to grounded junction gm8075 Electrical 3 03-28-2011 12:46 PM
Installing ceiling fixture with a metal junction box Romanuke Electrical 12 03-20-2011 03:37 PM
Junction boxes for garage T8 fixtures mazeroth Electrical 13 01-25-2010 10:52 PM
No Power at Electronic Air Cleaner Junction Box edge10 HVAC 1 09-28-2009 08:26 PM
