Joists, Acoustic Tiles And Romex - Is This OK? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-08-2010, 03:08 PM   #1
Question
Joists, Acoustic Tiles and Romex - is this OK?
Hi,
I am fixing my basement. I'll be installing acoustic tiles (i.e. hanging ceiling) from the ceiling joists. I'll also be installing receded lights (i.e. cans),type IC. For the lights I was planning to use regular Romex and staple it across the bottoms ( lenght-wise or cross-wise as required) of the ceiling joists, just above the tiles; instead of drilling the joists and passing the wires through the holes. Would this be OK? Or would I be contravening code?
globus999 is offline   Reply With Quote
Old 09-08-2010, 03:20 PM   #2
Licensed electrician
Rewards Points: 1,770
Cables smaller than 3 #8's or 2 #6's must be run thru bored holes or be run on running boards. Drilling the holes is not tough and will provide more protection for the cables.
globus999 (09-08-2010)
Old 09-08-2010, 03:41 PM   #3
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
I usually run electrical half way through the joists (less chance of causing weaknesses in them) and non electrical (ex: data) at the bottom of the joists using hooks.
You can get drill bits made for making these holes and with a decent (not super high end) plug in drill you can make these holes in like 2 seconds per, goes very well. Usually i find it easier to trace where I want the wire to go, then go and make all the holes, then pull the wire after.
The Following User Says Thank You to Red Squirrel For This Useful Post:
Old 09-08-2010, 04:09 PM   #4
Just call me Andrew
Rewards Points: 1,020
Does it have to be on a running board if it's above a suspended ceiling? I thought it didn't.
Andrew
secutanudu is offline   Reply With Quote
Old 09-08-2010, 04:27 PM   #5
Master Electrician
Rewards Points: 3,920
I believe you are correct. A suspended ceiling is considered protection from physical damage.
brric is online now   Reply With Quote
