Joining Romex And Conduit - Electrical - DIY Chatroom Home Improvement Forum
Old 11-08-2011, 01:24 PM   #1
Joining romex and conduit
We just bught a house and are remodling. I am removing 1/4" plywood panel and putting up drywall. I have gotten into the project and realised that we have an fpe stablok breaker panel acting as a subpanel. The system is wired in grounded emt conduit without seprate ground wiring in the conduit or ground bar at the subpanel. I tested the outlets with a test light and they appear to be grounded. Eventualy of course, I want to have someone swap this fpe panel out. For now I have the walls out. I want to put plastic boxes in and run romex wire.
What I wanted to know is there a way to ground the romex to the conduit at a junction box. Then later go from the junction box to the subpanel.
My second option may be to shim behind the current boxes or replace them to match the thickness of the drywall and not worry about it, but The outlets are sticking about a half inch out of the boxes with termanals very near those metal coverplates. and there is no ground wire conected. So I don't know how comfortable I'm going to be with this option.
Attached are pics. Any help is appreciated. Thanks in advance
Restyle is offline   Reply With Quote
Old 11-08-2011, 02:50 PM   #2
https://picasaweb.google.com/lh/phot...eat=directlink
Old 11-08-2011, 03:01 PM   #3
Licensed electrician
Rewards Points: 1,872
The flat rings you have can be replaced with raisded plaster rings. If you are using 1/2" drywall get 5/8" plaster rings.
If the conduit is continous it is your ground.
loose Romex entering EMT conduit inside ceiling amakarevic Electrical 6 11-02-2011 09:32 PM
loose Romex into plastic conduit box amakarevic Electrical 4 06-30-2011 09:27 PM
Why not Romex in Conduit? Mr Chips Electrical 3 11-08-2008 09:58 AM
Use of unsheathed Romex NM-B wires in conduit? WoodworkerDave Electrical 10 09-29-2008 05:57 PM
Cost Difference Between Conduit & Romex Shawns4 Electrical 39 08-25-2008 05:01 PM
