Jacuzzi Won't Turn Off - Electrical - DIY Chatroom Home Improvement Forum
Old 06-09-2012, 07:02 PM   #1
Jacuzzi won't turn off
We have a Jacuzzi Espree 6060 that we recently purchased (used, but in good condition) and installed. The motor is plugged in to an outlet with a timer. The first time we tested it, we turned the timer on and it immediately came on. I tried pushing the on/off switch and it would not turn off. So we turned the timer off to turn it off. I haven't closed it in yet, so I still have access to everything. I pulled the air tube off the on/off switch and checked to make sure it was pushing air out. It is. I pulled the switch off at the motor to check it also. I can hear it click when air is applied to it (tried it with a straw, then reconnected the air tube and tried it from the on/off switch.) I reinstalled the switch, connected the air tube, and gave it another try. When I turned the timer on, the jacuzzi did not come on. I thought, well, so far so good. I pushed the on button and it came on. I pushed it again and it turned off. Success! But that was short lived. I cycled it about 3 more times with success. And then on the last try, it stayed on. Won't turn off, unless I turn off the timer, which is several feet away on another wall. So you have to get out of the tub to turn it off, or let it time out. So now I'm back to where I started. Does this sound like the switch on the motor is bad? And if so, does anyone know a part # or where I can buy one? The owner's manual has no parts list. Couldn't find anything on the Jacuzzi website either. And I can't talk to them until Monday. Don't mind waiting, but thought some of you guys may have some ideas. Thanks in advance.
hand_in_ga is offline   Reply With Quote
Old 06-09-2012, 08:40 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,942
Sounds like the air switch is going bad. They are pretty much generic and lots of places online sell replacements.
mpoulton is offline   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
hand_in_ga (06-11-2012)
Old 06-11-2012, 04:43 PM   #3
Thanks for the reply. I didn't get off work in time to call Jacuzzi. I'll have to catch them tomorrow.
Old 06-17-2012, 07:23 PM   #4
Update
Well I ordered the air switch online and replaced it and it worked like a champ. Thanks again for the response.
Can't get unit to turn on need electrical help please-wiring diagram included igotshocked Electrical 33 01-30-2014 05:13 AM
Comfortmaker furnace won't turn on steelframe8459 HVAC 36 11-30-2011 03:22 PM
frost free faucet - cannot turn on terrealta Plumbing 9 04-03-2011 06:18 PM
Fan and A/C unit won't turn on cadmanim HVAC 1 06-22-2009 02:49 PM
Faucet won't turn off etiger Plumbing 1 08-31-2005 02:46 AM
