Jacuzzi Turns On After Power Outage - Electrical - DIY Chatroom Home Improvement Forum
Old 04-09-2011, 09:54 AM   #1
Jacuzzi turns on after power outage
We have a jacuzzi tub that seems to work fine in every way except for one.
Whenever our power is restored after a power outage, the tub turns on immediately by itself. This means that if we are asleep or not home following a power outage the motor is going without any water in the tub. Since we can't leave water in the tub 24-7 just in case of a power outage, our solution thus far has been to hit the button to turn off the related GFCI outlet every time after we use the tub.
Although this prevents the tub from turning on by itself, it also means we have to remember to hit the GFCI button BEFORE and AFTER we use the tub. It's very inconvenient..... especially if I've filled the tub up with water and gotten in and then realized the power's off at the outlet.
Why does the tub do this? And is there an easy fix? Is it just a bad or incorrectly wired GFCI, or is there something else going on?
neracny is offline   Reply With Quote
Old 04-09-2011, 10:04 AM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome to the forum.
I don't think there's anything wrong with the GFCI.
The jacuzzi is doing what it's programmed to do.
Your solution seems to me to be the easiest way to deal with it, however, I'd have to wonder why you have so many power outages?
Do you live near us? We lose power about 3 times a year on average. This last freezing rain we had took us out for 4 days.
DM
Old 04-09-2011, 10:07 AM   #3
Mad Scientist
Sounds like you might want to contact the manufacturer of the tub to see if that's normal behavior, if it can be changed somehow, or if a part might be defective.
McSteve is offline   Reply With Quote
Old 04-09-2011, 11:03 AM   #4
Rewards Points: 204
This for sure an issue that you must address. The tub should absolutely not turn on by itself. Do you have any of the paperwork that was left from the installation. Is there a drawing of the electrical circuit somewhere to get a look at?
Old 04-09-2011, 03:05 PM   #5
" Euro " electrician
frenchelectrican's Avatar
I agree with JV on this one and this part you will need to concat the manufacter of that tub and see what they can help you with it.
Many time when I test the jacuzzi or spa tub I play with the breaker to simauiated the power failure and turn the breaker back on and see how it react if they come on then I will concat the manufacter to see what to do with it.
Merci,
Marc
Old 04-11-2011, 04:27 AM   #6
Thanks all.
DangerMouse, I'm not sure how it's doing "what it's programmed to do". It's not on when the power goes off and there's no reason for it to come on when the power comes back. It's not good for the motor to run dry like that, so I would think it wouldn't just start running like that. Unfortunately we get frequent power outages, probably 4 or 5 during the winter months, lasting anywhere from an hour or two to a day or more.
I've contacted Jacuzzi to see if there's a solution. There was no paperwork left with the tub, no drawings or diagrams. If I don't hear from them, maybe I'll have my husband take off the access panel and we'll see if we can draw something up.
Old 04-11-2011, 05:25 AM   #7
Electrical Contractor
kbsparky's Avatar
It sounds like your unit has an electronic switch that resets itself every time the power is applied. It's possible that it has a SPDT mechanism that is wired backwards, and easy to correct. You want the default setting to be "off" instead of "on"
I'd keep using the GFCI to ensure the motor does not run dry, as you have been doind.
-KB
Old 04-11-2011, 06:44 AM   #8
the Musigician
Isn't it SUPPOSED to have water in it 24/7????
DM
Old 04-11-2011, 07:02 AM   #9
Mad Scientist
DM
You're thinking of a hot tub. The OP can correct me if I'm wrong, but I believe what we're dealing with here is smaller whirlpool bathtub.
Old 04-11-2011, 07:08 AM   #10
the Musigician
OK, ok.... I get it. When I lived in a gated community years ago, there was a Pool and Jacuzzi. Outdoors and always full of water.
I didn't catch the 'tub' part as being indoors in the bathroom..... if it was what I thought, I'd be correct.
Sorry.
DM
Old 04-14-2011, 08:29 PM   #11
Ah, sorry for the confusion. Yes, it's a Jacuzzi bathtub, not a hot tub.
I contacted Jacuzzi and was told that they've had other customers experience the same problem and that it might be corrected by putting a surge protector on the breaker. Maybe you guys can give me some insight... if we do this, does that mean the surge protector would divert some of the current and still give power to the circuit, or does it mean it would just trip the breaker when the power comes back on and shut off all power to that circuit?
In the meantime, we're going to look into what kbsparky said and see if we can find an SPDT mechanism. Sounds like it might be a simpler fix (or at least a more obvious one if it exists and we can see what it's set to).
Old 04-14-2011, 09:27 PM   #12
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
a surge protector isn't going to do anything for this. A surge protector is meant to shunt an over voltage to ground so the equipment isn't damaged.
It sounds like Jkbsparky is probably on the right track.
You have a model number? Somebody here might be able to find something on the 'net to help you.
Old 04-15-2011, 09:19 AM   #13
mem
Rewards Points: 156
Don't mean to hijack, but this is interesting! I have the exact sort of problem relating to a remote controlled ceiling fan and light. Whenever power is restored after an outage the light comes on full bright, but the fan remains off. Any ideas?
mem is offline   Reply With Quote
Old 04-15-2011, 10:38 AM   #14
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
I know most computers can be programmed to turn on, stay off, or return to their original state (on/off) after a power outage. maybe the hot tub has a similar setting?
Old 04-15-2011, 12:08 PM   #15
Scared Electrician
Saturday Cowboy's Avatar
@mem that sounds like typical operation of cheap dimmers.
@OP I think taking off that access hatch might be your first step.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Power Outage Issue? rbjones6 Electrical 13 05-24-2011 12:59 AM
Wring for Lincoln Power Mig Welder vstoyko Electrical 17 01-15-2009 06:15 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
power outage jp66hill Electrical 4 01-22-2006 07:24 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
