Old 11-10-2009, 05:04 PM   #1
jaccuzi tub wire. please help
there was no way to put a gfci close enough for the short pump wire ti reach.
is there a safe way to permanently extend the cord and still be up to code????
thanks for any help
jim
fishtale is offline   Reply With Quote
Old 11-10-2009, 05:42 PM   #2
Xtreme DIY'r
A bathroom tub or a big hot tub?
The jacuzzi bathroom tubs the GFCI is usually installed inside the tub enclosure
Old 11-10-2009, 06:07 PM   #3
bathtub., but the back corner where the pump is, is made of block. i have the gfci's on the other end by the pipes and drain.
Old 11-10-2009, 06:14 PM   #4
Sure there was/is.
Don't extend the cord, extend the building wire.
Also, don't put the GFCI recep under the tub. Install the GFCI recep in a wall somewhere smart and use a regular recep to plug in the motor. If the GFCI does trip, you don't want to get under the tub to access/reset it.
220/221 is offline   Reply With Quote
Old 11-10-2009, 06:27 PM   #5
yes, but if i put it back there, then i cant hit the button. and the tubs in already.
Old 11-10-2009, 06:34 PM   #6
Electrical Contractor
Reread his post.
Put the gfci outside the tub area and run romex to a regular receptacle.
Then if it trips, you just reach down and reset, and not crawl under the tub.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 11-10-2009, 07:00 PM   #7
i would rather not put the plug out in the open
Old 11-10-2009, 07:04 PM   #8
Xtreme DIY'r
Install a GFCI breaker
Old 11-10-2009, 07:10 PM   #9
300zx's Avatar
Post
It's done all time we put them in the closet is there one on the other side and it's a GFCI deadfront with no outlets in it.
300zx is offline   Reply With Quote
Old 11-10-2009, 07:11 PM   #10
i didnt know there was such a thing.
but the tub is kinda in already.
i realy want to extend the cord if possably????
Old 11-10-2009, 07:12 PM   #11
300zx's Avatar
Post
There is another solution.
Old 11-10-2009, 07:17 PM   #12
300zx's Avatar
Post
Use the box you have there for a j-box is there enogh room to put a metal 4 square box on the concrete by the plug? then run your wire to there and use a gfci and a rs cover for gfci but if it ever trips you will go through reseting it
Old 11-10-2009, 08:44 PM   #13
does anyone know if i can use some sort of connector and make the cord about 3' longer????
thanks
Old 11-10-2009, 08:50 PM   #14
Xtreme DIY'r
You can't use an extension cord in a hidden area or for a pump AFAIK
As said you need to use the existing box as a junction box & move it closer
I used the blank face GFCI & its in the basement under the bathroom
So it's easier to reset
My tub does have a removeable skirt, but not interested in going under there to reset
Old 11-10-2009, 11:33 PM   #15
I think they call it a 3' extension cord
You could replace the short cord with a longer one but it will likely be a pain.
Adding a wall switch to a pull chain fixture abacuslearns Electrical 17 12-20-2011 07:02 PM
Burial wire and a seeming difference of opinion... SxS Electrical 19 02-24-2009 10:16 AM
Red wire is HOT genner Electrical 15 02-22-2009 09:14 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
