J-Box Safety - Electrical - DIY Chatroom Home Improvement Forum
Old 07-20-2014, 03:21 PM   #1
J-Box Safety
As long as there are no exposed wires can you use a 1/2" connector from 3/4" conduit when wiring ranges and ovens to power?
jmnyc is offline   Reply With Quote
Old 07-20-2014, 03:23 PM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
What kind of connector?
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 07-20-2014, 03:26 PM   #3
90 degree metal. Not even a weekend warrior here.. just trying to remedy an issue that was left for me when I bought the house. Electric oven connected to power with no cover on the J-box
Old 07-20-2014, 03:27 PM   #4
electures's Avatar
90 degree metal
AC, MC, Flex?
Old 07-20-2014, 03:29 PM   #5
Sorry - flex
Old 07-20-2014, 03:30 PM   #6
electures's Avatar
Sorry - flex
As long as you use a listed device to connect the two.
Old 07-20-2014, 03:32 PM   #7
Pardon my ignorance and obvious lack of knowledge ... listed device?
Old 07-20-2014, 03:34 PM   #8
Licensed electrician
Rewards Points: 1,876
How are you going to fit a 1/2" connector on 3/4" flex? You need a 3/4" Greenfield connector.
Old 07-20-2014, 03:36 PM   #9
All I know is I've got wires coming from the range and oven wrapped in 3/4" conduit and connected to power via 1/2" flex connector. I was told this may not be safe but when I looked into it all of the wires are connected properly (black to black, etc.) and there are no exposed wires. Units are working fine. Just trying to verify that this is not a dangerous situation
Old 07-20-2014, 03:57 PM   #10
Just because it works does not mean it is safe or correct.
Old 07-20-2014, 04:06 PM   #11
Rewards Points: 14,306
No one here can see what your seeing.
Add some pictures, sure does not sound safe.
Trap and washing machine safety drain pan wildbilly Plumbing 18 03-05-2013 07:08 PM
Are these good respirators and safety masks? darsunt Tools 3 02-24-2013 07:34 PM
Safety Marty S. HVAC 1 11-07-2012 06:48 PM
Homeowners And Safety. Roofmaster417 Roofing/Siding 0 05-03-2011 11:41 PM
Garage Door Questions: closing sides and safety reversal jage Building & Construction 10 11-10-2009 07:57 AM
