J-B Weld To Mount Metal Box - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-25-2010, 11:35 PM   #31
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Originally Posted by plummen View Post
thats why ya put a coupling on the top of pipe and nice radius/curve in the romex where it goes into the top of it.im doing a basement rough in tomorrow or thursday,ill take some pics of how i do it
coupling? use an arlington bushing, It's cheaper.
you still cannot strip NM like that.
Old 01-26-2010, 07:25 AM   #32
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
how do you run plugs on a block wall in a basement when youre rocking the ceiling without sleeving the wire in the pipe?
plummen is offline   Reply With Quote
Old 01-26-2010, 09:53 AM   #33
nap
You talking to me?
nap's Avatar
there are limited allowances of NM in conduit for protection such as you are doing. I am not familiar enough to advise on the limitations without looking, and I have not had a chance to do it since I read this, but I do know that it is illegal to strip the sheathing from NM and use the wires inside as individual conductors unless they are rated to be used as such.
Old 01-26-2010, 10:44 AM   #34
CodeEnforcer
HIVOLT's Avatar
Rewards Points: 99
Nec 334.15 (c)
HIVOLT is offline   Reply With Quote
Old 01-26-2010, 02:31 PM   #35
nap
You talking to me?
nap's Avatar
Originally Posted by HIVOLT View Post
Nec 334.15 (c)
it seems to me that one of the other pro sparks had mentioned they further refined that in the '08 code with a limitation or clarification.
I'm going to have to go hunt up the 08 to see if I can find it.
Old 01-26-2010, 02:46 PM   #36
CodeEnforcer
HIVOLT's Avatar
Rewards Points: 99
This is from the NEC 2008
Old 01-26-2010, 04:26 PM   #37
plummen's Avatar
im not talking about stripping the sheathing and feeding the wires from box to box inside of conduit,im referring to using the conduit to sleeve the 4-5' of romex on an end run to a box.its still a continuous piece of romex running to the panel or where ever its fed from to the plug/switch box.does this make sense?
Old 01-26-2010, 04:38 PM   #38
CodeEnforcer
HIVOLT's Avatar
Rewards Points: 99
It is allowed as long as the outer sheath is not removed.
NEC 335.14 (C)
Old 01-26-2010, 05:26 PM   #39
nap
You talking to me?
nap's Avatar
NEC 335.14 (C)
ok, explain how OP will conform to 314.17 a and b
then 334.30
and has he even considered fill limits
Old 01-26-2010, 05:49 PM   #40
CodeEnforcer
HIVOLT's Avatar
Rewards Points: 99
I see my apprentice son is back using my screen name to answer questions. Guess he has not learned his lesson. Give me a few to read the original post and I will answer your question.
Old 01-26-2010, 06:24 PM   #41
nap
You talking to me?
nap's Avatar
that is too funny , have him register with his own screen name.
Old 01-26-2010, 06:28 PM   #42
CodeEnforcer
HIVOLT's Avatar
Rewards Points: 99
then 334.30
After talking to the wannabee he stated he was posting the NEC Article that states the sheath must be intact. He then answered another poster and meant to type 334.15. There isn't an Art 335 in the code book.
Old 01-26-2010, 06:39 PM   #43
nap
You talking to me?
nap's Avatar
I didn't bother to check. I simply accepted he was correct in his statement, at least as far as the sheath being intact goes.
is there a 334.14 in the 08? I have an 05 on my computer I usually use and three is no 334.14 in the 05.
dang, I really need to go hunt up my 08.
Old 01-26-2010, 07:28 PM   #44
Learning by Doing
Leah Frances's Avatar
Maybe this is a newbie question but why not use BX instead of conduit?
Also, to OP,
- I think your comment experience with JB Weld> metal screws was pretty insightful. JB Weld seems like a good option because you don't know how/are intimidated by the better solution.
- The beauty and curse of DIY is that you have to learn new skills. It's why I really love doing it. It's also why it can be cheaper and faster to pay a pro to do certain things - they already know to do things efficiently and correctly.
- So, get some metal screws and whatever other tools you're going to use and PRACTICE - before you know it you'll feel like a pro.
- You'll be alot more proud of your work if you do it right the first time rather than wishing at some time down the road that you didn't have to hammer some JB Weld off a box.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 01-26-2010, 08:18 PM   #45
...and has he even considered fill limits
I've made my mistakes regarding fill limits before. I double checked that when sizing the juntion box at the top of the conduit because it's going to have a bunch conductors going into it.
You see, the switch is a 4-way in a "handy box". That means two 14/3 Romex and 4 THHN coming together in the junction box at the ceiling.
I looked up fill limits and got a 4x4 junction box that is deep enough for the 10 conductors, and the chart I found said I'm ok with the 4 conductors in 1/2" conduit. The only thing I didn't double check before getting started was the fill limit on the "handy box", and I seem to be pushing it with 4 conductors.
Ok, I just did some quick research that indicates a handy box is 13 cu.in. With four conductors, a ground, and a switch, that means the box is 1 cu. in. too small.
HooKooDooKu is offline   Reply With Quote
How to mount outside light on metal garage stryped Electrical 12 09-29-2009 02:43 PM
Plasma Mount into Metal Studs davewolfs Home Theater 24 05-21-2009 08:23 AM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
