Old 09-09-2011, 10:58 PM   #1
its a 208y system
i have a 3 phase, 208y system in my warehouse, but was given an air conditioner to put in it that needs 480/3 phase/60hz power, can I use my current system or do i have to buy a new ac???
jharkness031 is offline   Reply With Quote
Old 09-09-2011, 11:15 PM   #2
Licensed electrician
its a 208y system
You would need to add a transformer to step the voltage up to 480.
Old 09-09-2011, 11:24 PM   #3
its a 208y system
so, would an air-conditioner for a 2000sq ft warehouse run off of a 208 system, or what should i do?
Old 09-09-2011, 11:41 PM   #4
its a 208y system
With the added step up transformer the air conditioner will need 2.3 (with a safety margin to account for less than perfect tranformer efficiency make that 2-1/2) times as many amperes out of your 208 volt system compared with the amperes in 480 volts specified on the air conditioner name plate. So you need to double check to see if your system can provide the needed amperes.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 09-10-2011, 02:24 AM   #5
" Euro " electrician
frenchelectrican's Avatar
its a 208y system
What size main breaker you have in there now ??
A HVAC contractor should assit you on the sizing the unit due there are few factors it need to cover on the A/C unit.
Most common we do from time to time is use the transfomer to upstep the voltage from 208 to 480 volts.
If you know the nameplate or tonnage of that unit we can able dail in to see if that unit is big engouh to handle the load of the A/C unit.
And have a electrician to assist you on the hook up due that is a commercal location anyway.
Merci,
Marc
Old 09-10-2011, 06:52 AM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
its a 208y system
Possibly. Call an electrician.
You are obviously way over your head as far as this goes and this is a commercial setting.
There is also a very real chance that it would be illegal for you to even do this work.
Old 09-10-2011, 06:53 AM   #7
its a 208y system
As an opinion, you would be crazy to go through everything you would need to to use that A/C. NOT worth it at all.
The Following User Says Thank You to Speedy Petey For This Useful Post:
J. V. (09-10-2011)
Need advice RE: purging air from baseboard hot water heating system mikenri HVAC 2 01-19-2011 08:17 PM
Open Hydronic Heating System... how / need to bleed? MtnMan7 HVAC 1 11-19-2010 04:51 PM
beware humidity system? Emaderton3 HVAC 5 02-11-2010 12:52 AM
Size A/C system properly 70stang HVAC 1 03-26-2006 08:22 PM
Replace furnace, coil and duct system sps123 HVAC 2 01-07-2006 11:56 AM
