Old 01-28-2011, 08:01 PM   #1
Issue with thermostat wiring for baseboard heater
Hi,
Lately I have had a baseboard heater in my office space run constantly no matter if the thermostat was turned down or not. I have replaced the old single pole thermostat with a new double pole model (Dimplex) and seem to have the same problem even though I have turned the thermostat off.
I am figuring that I must have made an error in wiring it up and was looking for some assistance.
The box has 3 sets of wires coming into it, line (supply) in the top, load out to the heater in the bottom and another that I am assuming is carrying supply power to the heater in the next room.
What I have done is to connect the red line wire to the red wire I am sure is carrying power then to one of the red line wires on the thermostat. I have done the same with the black line wires. I then wired the red load wire to one of the load wires on the thermostat and did the same with the black on the other (see diagram). All grounds are tied together and to the box.
Could someone please advise as to how I can get the thermostat working and the heat down before my electric bill is higher than the national debt?
Thanks for any and all help
Jeff
jschell is offline   Reply With Quote
Old 01-28-2011, 09:15 PM   #2
Electrician
That is the proper connections for a double pole thermostat, trying switching the "carrier" and the load. Maybe the wires are reversed from what you are thinking.
darren is online now   Reply With Quote
Old 01-28-2011, 11:36 PM   #3
I=E/R
a7ecorsair's Avatar
On my Cadet baseboard heaters with thermostat, the two red wires are connected to the line and the two black wires are connected to the load.
a7ecorsair is offline   Reply With Quote
Old 01-30-2011, 08:30 AM   #4
You know, I had it wired with the load and the carrier switched originally, but I guess the room was still so warm that the heater didn't kick in. I wired it back that way turned it up to full and sure enough it came on and also (more importantly) went off when I turned it off.
Thanks darren
To a7ecorsair: that is the same on this one my diagram was labeling the wires in the box itself.
heat pump wiring problem - new thermostat tygrr94 HVAC 8 01-17-2011 09:18 PM
Honeywell thermostat wiring wcb22 HVAC 5 01-10-2011 06:54 AM
Thermostat wiring Problem TRC Electrical 2 09-23-2010 08:37 AM
"sticky" gas water heater thermostat homer12 Appliances 8 01-25-2008 05:36 PM
"sticky" gas water heater thermostat homer12 HVAC 7 01-22-2008 07:08 PM
