Iso Ground Circuit On GFI Breaker - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-20-2011, 08:30 PM   #16
Code05's Avatar
Rewards Points: 1,104
Originally Posted by jlmran View Post
I didn't know that DC circuits were grounded.
VIII. Direct-Current Systems
250.160 General. Direct-current systems shall comply
with Part VIII and other sections of Article 250 not specifically
intended for ac systems.
250.162 Direct-Current Circuits and Systems to Be
Grounded. Direct-current circuits and systems shall be
grounded as provided for in 250.162(A) and (B).
(A) Two-Wire, Direct-Current Systems. A 2-wire, dc system
supplying premises wiring and operating at greater than
50 volts but not greater than 300 volts shall be grounded.
Exception No. 1: A system equipped with a ground detector
and supplying only industrial equipment in limited areas
shall not be required to be grounded.
Exception No. 2: A rectifier-derived dc system supplied
from an ac system complying with 250.20 shall not be required
to be grounded.
Exception No. 3: Direct-current fire alarm circuits having
a maximum current of 0.030 ampere as specified in Article
760, Part III, shall not be required to be grounded.
(B) Three-Wire, Direct-Current Systems. The neutral
conductor of all 3-wire, dc systems supplying premises wiring
shall be grounded.
Code05 is offline   Reply With Quote
Old 08-20-2011, 08:39 PM   #17
Rewards Points: 506
Thanks.
jlmran is offline   Reply With Quote
Old 08-20-2011, 08:56 PM   #18
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,950
I laugh when I see IG receptacles in a residential setting. They are completely useless in a home.
Speedy Petey is online now   Reply With Quote
The Following User Says Thank You to Speedy Petey For This Useful Post:
Code05 (08-20-2011)
Old 08-20-2011, 09:09 PM   #19
Code05's Avatar
But they is so purty and da fella at Radio Shack sez I needs dem.
Old 08-21-2011, 09:51 AM   #20
I=E/R
a7ecorsair's Avatar
Well, you check with the guys at HD and see if they agree
a7ecorsair is offline   Reply With Quote
Old 08-21-2011, 10:01 AM   #21
Code05's Avatar
Most of the clerks at HD or Lowes are clueless. They give the wrong advice all the time. I like to go in and correct them just for fun.
Old 08-21-2011, 10:06 AM   #22
Licensed electrician
Rewards Points: 1,502
Not really complete unless run with oxygen free copper wiring and have the silver plated triple wipe blade slots.
Code05 (08-21-2011)
Old 08-21-2011, 10:38 AM   #23
Code05's Avatar
Here is one for the truely foolish and clueless. Only $148.00. What a deal.
http://www.parts-express.com/pe/show...number=110-439
Old 08-21-2011, 12:44 PM   #24
JOATMON
ddawg16's Avatar
Rewards Points: 1,466
What type of meter are you using?
I just now used my Fluke 179....but as we both know, that is not really the right meter....I just keep forgetting to grab the megger that I have access to...
But the Fluke told me enough....anchor bolt not touching rebar to uber ground....20K-400K...hold down bolt touching rebar to uber...a couple of ohms...
I stuck my meter probe in the dry ground a couple of feet from the slab...about 400K
ddawg16 is online now   Reply With Quote
Old 08-21-2011, 04:43 PM   #25
Rewards Points: 6,652
That goes up there with the Monster cables, and some of the other quack medicine for a/v.
Old 08-21-2011, 04:46 PM   #26
I did it, due to we have dirty power during the Summer, and did not want to deal with the problems associated with it. Yes it is overkill, but then again, I put in a whole house surge in the panel, and use surge protectors on all of my electronics.
Old 08-21-2011, 05:43 PM   #27
I=E/R
a7ecorsair's Avatar
Mounting strap, rivets and grounding strip are gold plated, solid brass for the ultimate in corrosion resistance and power transfer.
Hey, it makes perfect sense to me, I wouldn't want a mounting strap that couldn't carry the full power of the cover mounting screw. Do you have to use a gold plated cover and screw too
This is extremely important when mounted in a plastic box.
Old 08-21-2011, 05:47 PM   #28
I do not believe in that overpriced crap from Parts express. Yes, it is a standard IG. I had the outlet lying in my parts box when we moved into the house, and figured that I may as well use it, instead of letting it sit in the box and doing nothing.
Old 08-21-2011, 05:58 PM   #29
JOATMON
ddawg16's Avatar
I just had to click on the link.....oh boy......did anyone read any of the reviews? Me kinda think that none of the reviewers actually bought one of those units...but in fact were just having a little fun.....but, if by any chance they were serious? I have some magnetic flux audio quilalizers I want to sell them.
Gold plated contacts? GMAFB
Shhhhsssssssttttt....don't tell them that copper is 33% better at conduting elctricity than gold......
On a side note.....about the only advantage gold has over other materials....it does not corrode....the most common use is with real low currents....
Old 08-21-2011, 06:15 PM   #30
Yes. That "gadget" got beat up pretty good a while back on DSLReports.com & AVSForum.com, along with some of the other quack audiophile gear. Computer circuit boards still contain Gold, especially with satellites, because it does not breakdown like Silver does. There are some $20,000 speaker cables, etc out there that also go up there with that outlet. Did I forget to mention, that there are purists that believe in this stuff.
Here you go for $2,000 power cords, etc. http://www.shunyata.com/
Add to it, $7,250 Audio cables http://most-expensive.net/audio-cables
http://www.noiseaddicts.com/2008/11/...st-audiophile/
Is it possible to change Circuit breaker to Buss fuse socket type? njchen24 Electrical 8 08-07-2011 06:27 PM
New circuit breaker owen22 Electrical 14 01-12-2010 07:08 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Circuit out but circuit breaker didn't trip PaulenAndrew Electrical 17 08-16-2008 08:38 AM
Circuit BReaker Question - breaker didn't trip and no power thru the circuit Ronin_67 Electrical 2 08-08-2008 06:06 AM
