Irrigation Pump Pressure Switch Melted - Electrical - DIY Chatroom Home Improvement Forum
Old 09-02-2012, 04:29 PM   #1
irrigation pump pressure switch melted
i'm using a sta-rite shallow well pump for an irrigation system. an electrician installed the breaker at the breaker box and the ground wire. i wired the pump start relay and also wired the pressure switch. the pump worked great for a couple months but i happened to look at it today and it's fried. i'm not sure what happened any help would be appreciated
irrigation is offline   Reply With Quote
Old 09-02-2012, 07:00 PM   #2
Electrical Contractor
kbsparky's Avatar
Loose connection, either on one of the wire terminals, or a bad contact.
Replace the pressure switch and try again.
-KB
Old 09-02-2012, 07:49 PM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Loose connection was my first thought as well.
The Following User Says Thank You to k_buz For This Useful Post:
jbfan (09-02-2012)
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-09-2011 12:00 AM
low water pressure from well pump supply dolfan13jmb Plumbing 4 03-03-2011 02:28 PM
Well Pump pressure switch help needed. slabm7 Electrical 20 11-03-2010 06:56 PM
New pressure switch and inducer and still incorrect drafting kevintabb HVAC 5 01-19-2010 01:59 PM
well pump wires to pressure switch american501 Electrical 2 12-01-2009 09:13 PM
