Old 01-17-2013, 03:38 PM   #1
ironing center
My wife just came up with an ironing center - you know, the fold down ironing board with a light and receptacle on a timer so you can leave the iron plugged in and the power will shut off in x minutes. This is a good time for it because the sheetrock hasn't yet been installed on this part of our remodel.
My question: can I wire this to a 20A outlet directly below it. I'd like to. The ironing center says 15A on the plate. This part of the project hasn't been inspected yet ( next week, hopefully), and I don't want to do anything that would be a violation.
Thanks.
Joe
Cornhusker Joe is offline   Reply With Quote
Old 01-17-2013, 05:24 PM   #2
Electrical Contractor
ironing center
Where is it located?
Shouldn't be a problem to wire it the the receptacle below.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 01-17-2013, 11:07 PM   #3
ironing center
Thanks for the prompt reply and helpful advice JBfan, I was just concerned about connecting a 15A appliance to a 20A circuit.
Thanks again.
Joe
portable generator to load center old blue Electrical 1 07-06-2012 01:41 PM
Ironing Center Cbeaty Off Topic 3 04-10-2012 11:57 PM
Ductwork Around Center Beam Build HVAC 6 06-16-2009 11:56 AM
Jacking up house, full length joists raised beam off of center colums. Suggestions? slowjo Building & Construction 8 04-05-2009 10:20 PM
Moved ceiling light in bedroom to center, now trips breaker blthomas Electrical 18 01-24-2008 05:29 PM
