Inverters - Electrical - DIY Chatroom Home Improvement Forum
Old 04-21-2009, 03:02 PM   #1
inverters
whats the biggest inverter i can run of a car lighter
bigrabw is offline   Reply With Quote
Old 04-21-2009, 03:10 PM   #2
BIGRED
Rewards Points: 252
Anything that uses 30A or less. Take a look at your car's fuse box. There is a fuse in there for the cigarette lighter. Usually you can get away with a 500W inverter through the lighter socket. Just remember to run the engine. Those little inverters are not soft start so they try to pull the maximum amperage from the battery ALL THE TIME.
Grampa Bud is offline   Reply With Quote
Old 04-21-2009, 03:11 PM   #3
Depends on what the plugs rated and what fuse feeds its. First of all, never replace a fuse with a larger one, unless you want your car to start on fire.
rgsgww is offline   Reply With Quote
Old 04-21-2009, 05:31 PM   #4
You want sine, square or reconstructed sine on the output waveform?
Old 04-22-2009, 01:48 AM   #5
Rewards Points: 1,016
I use quite a few inverters - I use the Tripplite units. The model PV375 is the largest capacity they provide for plug in use. Larger units are direct wire.
Specifications here:
http://www.tripplite.com/EN/products...=320&EID=14597
Need Advice (power Inverters for Ice Cream Truck) garagemaxx Electrical 4 05-15-2007 06:53 PM
