Inverter Help??? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-22-2008, 09:46 AM   #1
Question
Inverter help???
Can I combine 2 600 watt inverters to make one 1200 watt power inverter, I am a do it yourself tinkerer, and I really need to know if this is even possible. Please respond ASAP.
lady_becki05 is offline   Reply With Quote
Old 10-22-2008, 10:40 AM   #2
Rewards Points: 58
Are these static (VFD) or rotary inverters?
Old 10-22-2008, 12:05 PM   #3
Rewards Points: 2,350
Not unless you can force the two into phase. AC isn't quite like DC. If you could build a circuit to control the phase of each inverter in relation to the other, then yes, it would work. But right out of the box.. no. I have 1500 watt inverter that I bought at a truck stop for $50. It was used but man does it work!
Old 10-22-2008, 12:11 PM   #4
DIY'r
ScottR's Avatar
I'm guessing you mean these:
In which case, unless you have two very fancy ones: No.
The AC outputs of the two inverters would not have sync'd sine (or square) waves, so you would end up with some weird combined voltage.. somewhere between 0 and 240.
Bah, crossed posts.. what he said ^^^^^.
ScottR is offline   Reply With Quote
Old 10-22-2008, 07:23 PM   #5
" Euro " electrician
frenchelectrican's Avatar
You can not parallel the plain jane inverters at all due lack of schronous control.
If you do you will get weird voltage or destory unit one of the two.
Merci,Marc
Old 10-23-2008, 12:09 PM   #6
Rewards Points: 58
Wheres the OP? If she does in fact have VFD's in mind, she can use more than one to increase output current. It's called a "shared bus".
Old 10-23-2008, 02:00 PM   #7
Just buy a 1200 watt inverter. They are pretty cheap these days.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Computer on Generator capt2 Electrical 16 10-23-2008 11:23 AM
I need help getting down some of the basics. MEd!c Electrical 2 08-31-2008 02:55 PM
Wiring Size Calculations? SWAMI Electrical 30 07-27-2008 06:21 AM
Power inverter AndrewL Electrical 6 03-02-2008 02:43 PM
