Interrupted Freezer Circuit... - Electrical - DIY Chatroom Home Improvement Forum
Old 07-22-2011, 02:22 AM   #1
NCmeasure2x
Interrupted freezer circuit...
Thought I could remodel a basement outlet circuit but have messed up. I removed an outlet in middle of circuit by cutting load and line wires and joining them together with wire nuts. I wanted to move the outlet lower to floor so I ran another wire into metal outlet box and joined all the blacks with white wires and ground. Used the tester and the tester light indicated it was hot. However two hours later I walked into the garage and the freezer was off. Tester indicates it is hot but not working. I luckily caught my error and ran a power cord to freezer before I crash for the night. Any solution would be great.
I cut an outlet out and used this box as junction to tap into for new outlet. The old outlet box know has three black wires joined and three white joined.
Appreciate some insight.
mazac66 is offline   Reply With Quote
Old 07-22-2011, 02:42 AM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,920
Just to clarify, you connected all three blacks together, all three whites together, and all three grounds together? And the receptacle for the freezer was hot when tested with a test light? Sounds like you did everything right and it works, but there was something wrong with the freezer. Do other things work when plugged into that receptacle?
mpoulton is online now   Reply With Quote
Old 07-22-2011, 02:42 AM   #3
Rewards Points: 77
I'd check your connections, especially the neutral in the now junction box
CheapCharlie is offline   Reply With Quote
Old 07-22-2011, 06:07 AM   #4
NCmeasure2x
I will check the connections in new junction box. Thanks for the support and great site.
Dispute: Oven malfunction after h/w guys used the circuit rational Appliances 18 05-17-2011 10:37 PM
Bathroom Fan/Outlets on Same Circuit rjschwar Electrical 6 04-22-2011 10:56 AM
Changing a 3 way circuit...using recessed lighting box as a junction box? Oxymoron Electrical 1 12-07-2009 06:46 PM
Two Different Wire gages on Same Circuit OK? Lovegasoline Electrical 5 12-02-2009 05:00 PM
Dedicated freezer circuit in basement? budde97 Electrical 5 02-15-2007 03:09 PM
