Intermatic Digital In-Wall Timer ST01C - Electrical - DIY Chatroom Home Improvement Forum
Old 03-02-2009, 01:14 PM   #1
I bought one of these this weekend, but went to install and got confused. Well it shows that they are good for single switches, but this is going to replace a swtich that is acting like a pass through so it has no white wire. The current has one black wire coming into it and one going out to the next wirenut grouping and has no white wire at all.
On the timer switch it has a black wire, red and blue. I can't tell from the diagram how i'm supposed to get the power back to the other outlet? How do i wire this???
http://www.intermatic.com/Default.as...cid=43&sid=112
themayor is offline   Reply With Quote
Old 03-02-2009, 03:15 PM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Take the wires that were connected to the old switch and connect one of them to the black wire of the timer and connect the other one to the blue of the timer...cap the red it is used for a 3 -way switch. Nothing will change from the old set up other than whatever was switched will now be timed to come on and off depending on the programing.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 03-02-2009, 03:21 PM   #3
Does it matter which one goes to which?
Old 03-02-2009, 03:22 PM   #4
Just for laughs, does your load type and load current fall within the spec'ed values?
Old 03-02-2009, 03:28 PM   #5
How would I tell? I'm just trying to replace the switch
Old 03-02-2009, 03:42 PM   #6
Rewards Points: 1,578
Mayor,
I have one of them; wait until you go to program it. Wiring it up is child's play compared to their programming regimen.
bob22 is offline   Reply With Quote
Old 03-02-2009, 03:50 PM   #7
Resistive: 15 A, 120-277 VAC [a heater]
Tungsten: 15 A, 120 VAC, 6 A, 208-277 VAC [an incandescent lamp]
Ballast: 8 A, 120 VAC, 4 A, 208-277 VAC [a flourescent lamp]
Motor: 1 HP, 120 VAC, 2 HP, 240 VAC
DC Loads: 4 A, 12 VDS, 2 A, 28 VDS [no DC in your house, I assume]
Old 03-02-2009, 03:51 PM   #8
i'm just looking to put my two exterior lights on a timer so i dont always have to remember to turn them off in the morning. I should be good?
Old 03-02-2009, 03:55 PM   #9
Yes, up to 15A x 120v=1800w total lamp load.
Old 03-02-2009, 05:14 PM   #10
UAW SKILLED TRADES
Stubbie's Avatar
No it doesn't matter
Stubbie
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 08:21 AM
Framing Question: How thick the wall that carries plumbing? jaes Carpentry 5 06-18-2008 05:39 PM
Digital timer problems bazzer Electrical 4 11-20-2006 05:44 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
Load Bearing Wall rpatterson Building & Construction 2 10-29-2005 07:43 AM
