Interlocking Bath Fan With Furnace Using Relay And Transformer - Electrical - DIY Chatroom Home Improvement Forum
Old 02-01-2012, 06:39 PM   #1
interlocking bath fan with furnace using relay and transformer
i have a two wire to the interlock switch from the furnace room and a three wire to the fan switch to the interlock. i have also got the relay and transformer kit required. in the switch box in the bathroom i only have switch legs no neutral. could you show a wiring diagram.
drmclovin is offline   Reply With Quote
Old 02-01-2012, 07:34 PM   #2
Missouri Bound's Avatar
I'm sure that what you are saying makes perfect sense to you, but I unfortunately haven't a clue what it is that you want to do.
Here's what I (we) need to know:
What interlock and what for?
What's the relay and transformer for?
...and you almost always need a neutral.
Do you want it your way or the right way?
Old 02-01-2012, 07:40 PM   #3
Rewards Points: 13,450
What in the world does a bathroom fan have to do with all these controls.
Old 02-01-2012, 07:54 PM   #4
joed's Avatar
Rewards Points: 12,402
He is probably in Canada and trying to interlock the bath fan with a HRV so they both can't run at the same time.
Old 02-02-2012, 01:21 AM   #5
" Euro " electrician
frenchelectrican's Avatar
Joed did hit the nail on that one and also I have did see that in Wisconsin as well so it is not specfically in Canada anymore due more and more homes are getting air tight so with exhaust fan kick on for some reason they will have to turn on the air make up unit ( sorta like heat exchanger but draw fresh air in )
Joecaption.,
It getting more common to see new home are more airtight and we just start doing that in European side as well.
Merci,
Marc
Old 02-02-2012, 05:28 AM   #6
Rewards Points: 3,256
Merci,
Marc
Very interesting. I would think the manufactures of the make-up units should include a pressure switch so people didn't have to do this hacky wiring.
zappa is offline   Reply With Quote
Old 02-02-2012, 05:30 AM   #7
You would have to run the cable to the vent fan or pull a new cable with neutral to your switch.
Transformer, Relay, Low Voltage Kermit911 Electrical 16 06-20-2013 04:18 PM
Payne Furnace Pains - Updraft/downdraft parts swap?? sticknca HVAC 1 12-12-2011 08:11 PM
Bryant 350MAV Furnace Code 31 Failure maq0 HVAC 0 10-10-2011 02:07 AM
Heating relay wiring Toledo Electrical 6 11-26-2009 12:03 PM
Central Ac transformer question Rschrei518 HVAC 4 10-20-2008 08:21 PM
