-   -   Interlock Kit for Generator (http://www.diychatroom.com/f18/interlock-kit-generator-124198/)
db_9 11-21-2011 02:26 PM
I am planning on getting an generator interlock kit installed into my main panel. I am going to get quotes from a few licensed electricians in my area. But I just want to be educated before talking to them. I know which interlock kit I need for my panel. So it need the top 2 right breakers to be free in order to install the breaker that will go to the plug outside of the house. Currently my well pump takes up these 2 slots in my breaker. I do have 2 free breakers on the right bottom of the panel. So I imagine that the electrician will just move my well pump to this location???? Does that sound right? If so how should this be done? I have read stuff about pigtails inside of the panel, etc.
Or would you guys suggest just getting a manual transfer switch installed instead? The only problem I see with those is you only get 10 or so breakers. I like the idea of being able to pick and choose what I want to use in my main panel with the interlock kit.
Thanks.
Speedy Petey 11-21-2011 03:14 PM
Yup. That's pretty much the drill.
What have you heard?
db_9 11-21-2011 04:21 PM
About the pigtailing, I probably have my terminology wrong as I am not an electrician. But thats why I am here :)
I guess what I am asking is this. When they wired the well pump originally I imagine they trimmed the wire when they were done. So there will not be enough existing wire to move the well pump to the new location in the panel. So how do you add more wire the correct way to move the breaker to the new location?
Thanks.
jbfan 11-21-2011 04:30 PM
Just add the lenght of wire you need to reach the breaker.
If you are in Canada, then you can not splice in the panel.
VelvetFoot 11-24-2011 12:20 PM
I installed my own SqaureD interlock and there was enough slack to make it work.
