Interlock - Electrical - DIY Chatroom Home Improvement Forum
Old 10-26-2012, 10:56 PM   #1
Interlock
Hi. I'm looking at interlock kits to connect my portable generator to my panel in times of power outages and want to connect it the safe way. My house was built in 1961 and has aluminum wires. I need to know if these wires can handle the use of the generator without causing any unsafe issues in the house. Thank you all in advance
Briandmozy is offline   Reply With Quote
Old 10-27-2012, 12:05 AM   #2
Electrical Contractor
kbsparky's Avatar
Which wires are aluminum?
Why would they not be able to handle the same thing that the utility provides?
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
Speedy Petey (10-27-2012)
Old 10-27-2012, 06:33 AM   #3
The wires in my home are aluminum(all wires feeding outlets). And I just have people saying to be carefull because those wires have been known to overheat.
Old 10-27-2012, 06:51 AM   #4
biggles's Avatar
the wires between the genny and the panel are the ones handling the house load in a storm condition.the exsisting house wiring(loads into panel) will be good as the house runs during a normal day/night,but being fed from the genny not the pole.lights,computers,TVs are minimal watts the refrigerator cycling is a draw,heating systems,appliances...etc.what is the wattage on the generator?
Old 10-27-2012, 08:30 AM   #5
Rewards Points: 776
You are no more at risk with either PoCo power or from a generator on branch circuits. They don't know where power source is from.. Aluminum installed properly is safe. It can be a problem when modified by someone not knowing the "subtle details"..
If you feed panel with an interlock kit on a dedicated branch circuit to genny you should be fine.
curiousB is offline   Reply With Quote
The Following User Says Thank You to curiousB For This Useful Post:
Old 10-27-2012, 09:17 AM   #6
Thank you everyone. The gen is 5500 and 8250 starting watts
Help trying to identify Main Panel circuit breaker Interlock solution Linos Electrical 9 05-16-2012 05:00 PM
Homebrew Generator Interlock Kelly62 Electrical 17 01-31-2012 12:13 AM
Generator Interlock Kit NJ Homeowner Electrical 2 01-01-2012 11:59 PM
Question about QO interlock kit / breaker. speedster1 Electrical 8 02-04-2011 07:19 AM
Which generator Interlock setup should I use for my sub panel? homerb Electrical 2 05-10-2010 04:44 PM
