Interior Or Exterior Panel To Feed Out Building? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-24-2012, 04:37 PM   #1
Rewards Points: 150
Interior or exterior panel to feed out building?
If I am to run a single circuit to my out building from my home does it matter if I start the circuit at interior main or exterior panel?
MikeVila is offline   Reply With Quote
Old 08-25-2012, 08:22 AM   #2
Rewards Points: 150
Have done plenty if electrical just never messed with exterior main panel. Just didn't know if it mattered but would save me from
Crawling under house with bad back!
Old 08-25-2012, 10:14 AM   #3
Rewards Points: 240
Do you have a panel inside and another outside? If the answer is yes, pick the one that will make the job the easiest. So tell us about these two (2) panels. Is one a main and the other a sub? Do you have a meter main service panel? What exactly do you mean "start a circuit from the inside panel or the outside panel"?
Old 08-25-2012, 03:12 PM   #4
Rewards Points: 150
The outside is where the meter and a 200A main service shut off to entire home.
Then there is the breaker box inside home which also has 200A shut off as well as all the breakers for all circuits of home.
Just didn't know if it mattered if I put a 20A in the exterior panel and run from there. Would be easier as I wouldn't have to crawl under house.
Old 08-25-2012, 07:58 PM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You could only start at the meter/main if there were additional spaces for a new breaker. You cannot just tap off the main over current protection.
Old 08-26-2012, 09:58 AM   #6
Rewards Points: 240
He can extend the service. Tap the service conductors or use lug adapters for tapping the meter.
Old 08-26-2012, 10:02 AM   #7
k_buz's Avatar
He is asking about running a single circuit. I don't think he is installing any over current protection. If he was I might agree with you.
Old 08-26-2012, 11:41 AM   #8
Rewards Points: 240
My bad.
Old 08-26-2012, 01:43 PM   #9
Rewards Points: 150
I'm wanting to put a 20A breaker in and run some outlets and lights in an outbuilding.
Don't know what referring to when discussing over current?
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 04:04 PM
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 08:47 PM
Steel freespan building with interior office build out viper Building & Construction 4 01-16-2011 07:31 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
feed to subpanel question JCA1 Electrical 1 03-11-2008 08:16 PM
