Interior/Exterior Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 12-19-2012, 03:05 PM   #1
First off thank you everyone on this forum, when a person needs help this is the place to go. I have a 2 gang box next to my patio door. One switch will be for the the living room lights and the other will be for my deck lights. I was wondering if I could bring one line in for both or do they have to be on separate breakers? Also if they both can be on one breaker does it need to be a gfci? Thanks for any input.
wood479 is offline   Reply With Quote
Old 12-19-2012, 03:08 PM   #2
Rewards Points: 13,750
Both can use the same incoming power, no need for a GFI or two differant breakers.
If you add an outlet then you need a GFI if it's outside.
Old 12-19-2012, 03:10 PM   #3
lights
Old 12-19-2012, 06:00 PM   #4
Licensed electrician
Rewards Points: 1,634
Technical correction. Only a receptacle would need the GFI protection. The lighting outlet does not.
Receptacles are outlets, but not all outlets are receptacles.
rjniles (12-19-2012)
Old 12-20-2012, 01:32 AM   #5
There is no need for GFI as both can use same power, its much more efficient for me...
CharlotteTaylor is offline   Reply With Quote
