-   -   Interconnected smokes (http://www.diychatroom.com/f18/interconnected-smokes-17307/)
CowboyAndy 02-19-2008 06:53 AM
We currently have a fully interconnected smoke system with a total of 6 detectors total. I would like to change 2 of them to combo Co2 units. Are all hard wired smokes and Co2 interchangable? If not, how do I know if they are?
ElectricianJeff 02-19-2008 07:03 AM
If the smokes are near 10 years or older than your best to replace them all. Smokes and Combo's are interchangeable but you need to stay with the same brand, lot#, etc.
Jeff
CowboyAndy 02-19-2008 07:13 AM
Well, they were kind of added as we remodeled, but I would say the oldest is only 2 years old or so, the newest about 6 months old. I would rather not replace all of them, but I guess worst case scenerio is I can't fint a combo unit from the same manufactorer and replace them all. I believe they are Kiddie brand from HD.
ElectricianJeff 02-19-2008 07:53 AM
Kidde makes a combo unit, try a couple of them and you will probably be good to go.
Jeff
CowboyAndy 02-20-2008 09:20 AM
Is there a way to know for sure they are interchangable before buying them? Is this something they should say on the package?
radon 02-20-2008 12:00 PM
I don't know about lot numbers, but I just wired my rehab project with brand K smoke and combo detectors. I have two CO/smoke detectors mixed in with about 6 smoke detectors. They communicate nicely. They're wired together like 3-way switches... with 12-3 wire. You've got two for power and one for signal. I don't know exactly how the detectors use that signal wire, but I would think it would be fairly generic. Over a certain voltage means a unit has detected a fire! Alarm!
Anyway, it's something you could easily try. If the unit you buy doesn't communicate with the others, return it... try again. I think if you hold down the test button long enough it will set off the others, right? If not, fog one of them with enough lysol to set it off :)
CowboyAndy 02-20-2008 12:03 PM
Okay, I think I will pick up just one this weekend when I go to Lowes, and if it works then I will pick up more next time I am out there.
Thanks.
