Old 11-13-2005, 03:45 PM   #1
integrating electrical surge protector into wall?
hi, i have a lots of electronic in my bedroom and living room that uses a power plug. i have about two HUGE power surge protectors in those rooms. is there a way i can build a power suge protector into the wall? i hate having those power surge protectors lying around the ground with miles of power plug entangling in each other.
aznboi04k is offline   Reply With Quote
Old 11-19-2005, 11:58 PM   #2
ryaniniowa's Avatar
Check with you power company. Where I live they offer power surge protection at the meter. This then protect the entire home. Just a thought.
ryaniniowa is offline   Reply With Quote
Old 11-20-2005, 11:19 AM   #3
Even if you have a whole house surge protector you still need a point of use surge protector. If a surge came in from, say, the phone line or cable into your powered cordless phone base station or your set top box, the surge might feed back into the electrical system. Also, if you house is not well grounded (even if it is) and lightning strikes very near your house you would be at risk if only you had a whole house system.
I don't know if they make receptacle boxed sized surge protectors.
bbarnhart is offline   Reply With Quote
Old 11-23-2005, 11:01 AM   #4
Long-Time DIYer
Mike Swearingen's Avatar
I have a "whole house" surge protector installed inside my 200 amp electrical panel. Fortunately, it has never been needed, but if it ever blows, I can easily replace it. Picked it up at a local electrical supply house, and I think that it was less than $30 bucks.
Of course, it doesn't protect anything through the phone line and I'm on cable for Internet, too, but I have a Back UPS Pro 650 surge protector and battery backup unit for my computer.
Can't get enough surge protection. Had a neighbor's house set on fire with an electrical surge through a nearby lightning strike on a power line transformer a few years ago.
Mike
Mike Swearingen is offline   Reply With Quote
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 04:49 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
How do I drill the hole in the wall if I don't know location of electrical wire popkadurak Remodeling 10 06-16-2006 11:06 AM
