Insulation Question - Electrical - DIY Chatroom Home Improvement Forum
Old 03-23-2013, 01:56 PM   #1
Insulation question
Hi,
I am adding another layer of insulation in my attic. Is it ok to put the batts right over the ceiling electrical boxes for my ceiling fans? Also, can it go over electrical wire since its sheathed?
miguel24932 is offline   Reply With Quote
Old 03-23-2013, 02:34 PM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Yes and yes as long as the cable is not bundled.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 03-23-2013, 02:48 PM   #3
Rewards Points: 6,652
You need to go around and seal any openings in the ceilings and walls, before doing anything with insulation. Also you need to place baffles between each rafter space, to allow air movement, and not allow insulation to get pushed up against the roof.
Old 03-23-2013, 04:52 PM   #4
what do you mean by bundled?
Old 03-23-2013, 04:55 PM   #5
Rewards Points: 13,694
Groops of wires tied together.
electures (03-24-2013)
Fixing multiple attic electrical issues before blowing in insulation darlingm Electrical 11 11-19-2011 09:19 AM
Another cape insulation question exiledgator Building & Construction 21 10-14-2011 08:42 PM
Garage insulation question trojanman1 Building & Construction 7 09-16-2009 02:51 PM
rafter insulation question Jeremy Hillary Boob, PhD Building & Construction 7 08-02-2009 08:19 AM
Insulation Question skavang13 Building & Construction 3 11-16-2008 05:08 PM
