Insulation And Electrical Wires - Tar Seep - Electrical - DIY Chatroom Home Improvement Forum
Old 05-20-2013, 08:45 AM   #1
Rewards Points: 172
Insulation and electrical wires - tar seep
The other day I was in my attic running nework wires and had to move some insulation. I noticed on the kraft facing there was tar seeping through where it was in contact with the romex wire. Looks as if the insulation was jut laid on top of the wire.
Is this normal?
The circuit that one of the wires was doing that is not overloaded - 3 hi hats, 2 ceiling fans, 1 stairway light and the smoke alarms (3). It is a 20A circuit...
I did go around the attic and put the wire on top of the insulation where I could (instead of it being buried underneath) and pulled the kraft facing off where i could not do that.
Thanks!
zephed666 is offline   Reply With Quote
Old 05-20-2013, 09:30 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,820
Let me guess....your house was built in the 50's?
Yea...normal. The attic gets warm enough for the 'black stuff' to stick to what ever the romex is next to. It's not an indication of the wire over heating.
Old 05-20-2013, 09:34 AM   #3
Rewards Points: 172
Yup, built in the 50s. But the wiring is newer.
Thanks!
Old 05-20-2013, 09:37 AM   #4
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,820
Dawg..... Just curiosity.... I call that wire "old Romex".... does it have a real/actual name. (My kids places 1949 and 53 is full of it)
MTN REMODEL LLC is offline   Reply With Quote
Old 05-20-2013, 09:44 AM   #5
JOATMON
ddawg16's Avatar
No idea....my house has the same thing...in reality, "Romex" is a trade name.....sort of like "Formica". People are so used to associating the name to a type of material that it becomes the name of the material.
As I understand it...the stuff we have came into being in the 30's as a replacement for Knob & Tube. It's insulated copper wire with a wrap of paper and then asphalt-saturated cotton cloth on the outside.
The Following 2 Users Say Thank You to ddawg16 For This Useful Post:
MTN REMODEL LLC (05-20-2013), Philly Master (05-20-2013)
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 08:49 PM
Run wires before insulation, or vice versa? sc2k2 Electrical 3 12-07-2011 07:15 PM
Fixing multiple attic electrical issues before blowing in insulation darlingm Electrical 11 11-19-2011 09:19 AM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
