Insulation Contact Okay Ceiling Light Can - Electrical - DIY Chatroom Home Improvement Forum
Old 10-13-2014, 02:40 AM   #1
Rewards Points: 141
insulation contact okay ceiling light can
Question about this lighting can: "the H99ICAT was designed to be used in insulated ceilings where insulation will be in direct contact with the housing. It is an AIR-TITE housing that has been designed to prevent air flow between unconditioned areas and living spaces."
Hi friends: Call me compulsive. I mean it says right above that this can can come in direct contact with insulation. And that is my plan. The five cans will be fully surrounded by basic pink insulation.
So I can trust this? No problem? Go ahead? Anything I need to know regarding safety for heat of cans and insulation before I lay it all in. The cans will be housing low wattage LED lighting units and I will lay flat lying pieces of insulation on all sides and over the top of the can.
(have great day)
DiegoJames is offline   Reply With Quote
Old 10-13-2014, 07:19 AM   #2
joed's Avatar
Rewards Points: 12,446
You can put insulation in contact with that can.
The Following User Says Thank You to joed For This Useful Post:
clw1963 (10-13-2014)
Old 10-13-2014, 07:54 PM   #3
Rewards Points: 141
Thanks!!
Question concerning a ceiling light and grounding mTorbin Electrical 5 02-07-2012 08:23 AM
5000k Light Blulbs for Ceiling Fan Fixture (clean white light for living room) cmf0106 Electrical 10 01-12-2012 10:04 PM
Ceiling fan light kit duhtroll Electrical 10 06-21-2011 02:29 PM
Existing Cathedral Ceiling Insulation Question Bob Deb Building & Construction 8 12-07-2010 07:54 PM
Part of a ceiling fan light fixture needs help...please g5729 Electrical 1 06-17-2007 06:22 AM
