Old 02-01-2009, 10:56 AM   #1
Question
Insulation around a electrical circuit breaker box
I have a circuit breaker box that is on the outside wall of my house and there is obviously a fair amount of cold Washington DC air coming in through this circuit breaker box. In the attached picture is the offending hole where the wires feed into the house. What is the best type of insulation I can put around these wires (the large wire bundle, not the wires in the blue brackets)? I can use caulk, typical wall insulation or even the expanding foam, but want to use the best product without affecting the operation of the circuit breaker box. Any help would be appreciated without causing an electrical/fire hazard.
Thanks, Bill
terpsing is offline   Reply With Quote
Old 02-01-2009, 01:34 PM   #2
nap
You talking to me?
nap's Avatar
this is what I typically use to plug holes such as this. It is removable if you need to and when worked throroughly, becomes quite pliable.
http://www.twacomm.com/catalog/model_31-601.htm
Old 02-01-2009, 01:39 PM   #3
Yep! This is stuff to use! in my circles, we refer to this as 'elephant dung'! LOL!
Old 02-03-2009, 03:50 PM   #4
nap
You talking to me?
nap's Avatar
not sure I want to be in those circles. I think the worst it is called around here is dum dum.
Old 02-03-2009, 04:08 PM   #5
UAW SKILLED TRADES
Stubbie's Avatar
Its interesting where they have the duct seal at our local home depot. It's over with the data com products where they stock the RG-6 etc.. They also have the wiring pull string and wire pulling lubricant there also.
Anyway I agree with the duct seal in your situation. The cable your talking about is a SEU and they do make a sealing bushing/connector for it. But to install one you would need to disconnect the service entrance so I'd go the duct seal route....l
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Main Circuit Breaker Test lthomps222 Electrical 16 11-07-2010 05:40 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Tandem Breaker and Circuit(s) whowadat Electrical 1 01-09-2009 05:13 AM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 08:59 PM
