Insulating Switch Plates - Electrical - DIY Chatroom Home Improvement Forum
Old 03-29-2008, 06:33 PM   #1
insulating switch plates
There is a draft from my electrical outlets, how do you insulate this?
boddah is offline   Reply With Quote
Old 03-29-2008, 07:44 PM   #2
Air seal at the top plates in the attic space to stop air movement or get the foam gaskets for each outlet or switch.
switchbax73 is offline   Reply With Quote
Old 03-30-2008, 10:15 AM   #3
Watch out if where you have dimmers. They get hot and can overheat.
Jeff
ElectricianJeff is offline   Reply With Quote
Old 03-30-2008, 11:54 AM   #4
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
In my state, we (electricians) are required to seal all unused openings into a box prevent this. We also must seal all openings between floors. You can buy foam gaskets to place under the switch and receptacle covers. That would be quick and easy.
jrclen is offline   Reply With Quote
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 09:34 PM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 05:06 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 02:53 PM
