Insulating Recessed Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 04-09-2009, 07:09 PM   #1
insulating recessed lighting
I plan on installing either 4 inch ic or 4 inch airtite ic cans in new construction. I am planning to use spray foam to do a flash and cellulose type insulation in the attic to achieve an r-80 insulation. There is no problem with room to achieve this,and I will use mini spirals in the can as I have done in the past without problem. Is there any reason I could not safely spray the cans to get a complete seal.
spiker is offline   Reply With Quote
Old 04-09-2009, 07:23 PM   #2
I'd make sure they are really sealed
Air can usually go into these thru cracks
You don't want them full of foam
Other then being a problem to change them out I can't think of any other issues
Old 04-09-2009, 08:30 PM   #3
Foam & cans
I just went through the same thing. You won't get the light manufacturers to allow you to foam the lights. They are worried about the thermals tripping. They don't seem to have a problem with cellulose (or whatever) in any amount top of them.
So what I did was to cover the cans with paper grocery bags. Shoot the foam. (I only put in an inch or two of foam, SIPS house) Remove the bags. And put in the cellulose. I only went for R 50 or R55.
lkg907 is offline   Reply With Quote
Old 04-09-2009, 09:04 PM   #4
Which Mfg's?
Do you have a link to where they state this?
I'm looking at Halo's site & I don't see anything limiting the type of insulation
http://www.cooperlighting.com/specfi...opdf/H7ICT.pdf
Old 04-09-2009, 10:02 PM   #5
Halo cans
Dave,
I went with Halos. 6" ICAT. A call to their customer service # is how I found the information on not foaming the cans.
Old 04-09-2009, 10:21 PM   #6
There is nothing exempting it in the box or on the box
No instructions stating it can't be used
Nothing on the can indicating it can't be used
If their online specifications do not exempt it & nothing in or on the box or fixture, then the info is bogus
If there is an exemption from use they would need to include that with the merchandise being sold
Insulating IC recessed lighting. topher0524 General DIY Discussions 4 02-10-2009 06:03 AM
Recessed Lighting - Quality Question. 811Gibbon Electrical 8 01-24-2009 09:47 PM
Recessed Lighting under hot/cold supplies?? KC10KEVIN Electrical 1 05-08-2008 10:21 PM
recessed lighting wiring to 3way switch DIY4EVER Electrical 1 07-12-2007 01:35 PM
recessed lighting in basement DIY4EVER Electrical 6 06-29-2007 02:52 PM
