Insulating Interior Wall Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 11-23-2010, 05:50 PM   #1
Insulating interior wall outlet
I need to insulate the light switches in my house that face opposite the exterior of the house. I know there are foam inserts that can be placed behind the switch plates that will help with that but what about expanding foam inside the box? Is it a workable solution? How should it be applied? Finally is this just creating a problem if the switches ever need to be replaced?
flyfisher is offline   Reply With Quote
Old 11-23-2010, 05:53 PM   #2
Why insulate on an interior wall ?
You need a specific foam & you can't really fill the box at all
Old 11-23-2010, 05:57 PM   #3
Licensed electrician
Rewards Points: 1,744
The foam cannot be sprayed inside the box.
SD, I think the OP means the boxes are on outside walls and face inward.
Old 11-23-2010, 05:58 PM   #4
concretemasonry's Avatar
Rewards Points: 2,626
Why worry about an interior supposed problem when there are better things to do to make the envelope more efficient and eliminate the need to chase possible interior problems?
Without knowing your location (climate) and construction and a lack of a specific problem it is hard to give advice.
Technically, an interior outlet is within the building envelop, so arbitrarily using insulation materials could never be justified and may cause other problems.
Dick
concretemasonry is online now   Reply With Quote
Old 11-24-2010, 12:04 AM   #5
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
If what your saying is that this is an exterior wall, but with outlets on the inside of that wall, inside the home, then yes, foam can be used around the outside of the boxes, but never any inside the boxes. If it is interior, as others said, it isn't worth it to insulate on inside walls unless there is some special application like a sound proof wall.
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 08:38 PM
Insulating an outlet box humberguy Electrical 0 03-29-2010 09:54 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
