Insulated Staples Needed? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-04-2010, 11:54 AM   #1
Tra
insulated staples needed?
I am rewiring my house after a copper theft, special thanks to Vermont Mutual for denying the claim, thus forcing me to be my own electrician::>
I bought a great book from Home Depot that gives a simplified explanation of the NEC, but there are some items missing.
I need to know if insulated staples must be used (for securing type NM cable) or whether I can buy the much cheaper standard type? The house was built in 1997 and all the existing staples are the bare wire type. But, since I have to tear out all the existing wiring and redo it, must I use insulated staples on the new wiring?
I also have a few other simple and minor questions-but have posted them separately so that the title of the message accurately reflects it's contents.
T
Tra is offline   Reply With Quote
Old 10-04-2010, 01:20 PM   #2
Licensed electrician
Rewards Points: 1,240
They are not required by the national electrical code, but your local area may. Check with your building officials.
Insulated Windows - Worth the extra money? VinDan Remodeling 10 07-30-2010 08:01 PM
Luan plywood staples under tile? former33t Flooring 3 10-15-2009 02:34 PM
Metal wire staples vs. Plastic wire staples tripower Electrical 14 02-18-2009 06:23 PM
Moisture problems when 'heating only when needed' in insulated garage? timg HVAC 10 01-18-2007 06:38 PM
Upgrading can lights to insulated? juliejules4 Electrical 2 12-03-2006 05:25 PM
