Insulated Staples - Electrical - DIY Chatroom Home Improvement Forum
Old 03-13-2012, 11:14 PM   #1
Insulated Staples
When is it necessary to use insulated staples? I bought a bunch of plain metal staples for wiring my garage with 12/2 and plan on leaving the walls open. There will be four 12/2 wire leaving/entering the switch box, can I use regular staples and staple two pair of wires side by side up the stud or do I need something else like stacker staples?
MisterSteve is offline   Reply With Quote
Old 03-14-2012, 12:27 AM   #2
Code05's Avatar
Rewards Points: 1,104
Stackers not required here as long as you adhere to keeping both sets 1 1/4" from edge of stud. Keep it tight.
Code05 is offline   Reply With Quote
Old 03-14-2012, 05:52 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,990
Do not staple two wires side-by-side, on edge. Keep them flat on top of each other.
Old 03-14-2012, 07:05 AM   #4
Code05's Avatar
Another option is to run 1 set down the middle and ty-wrap the 2nd set to the staple holding the 1st set. Do not just ty-wrap to the cables to cables because that is not totally legal. Cables may support cables.
insulating and insulated duct runs hummer4x4guy HVAC 4 01-09-2012 02:52 PM
insulated staples needed? Tra Electrical 1 10-04-2010 12:20 PM
Insulated Windows - Worth the extra money? VinDan Remodeling 10 07-30-2010 07:01 PM
Luan plywood staples under tile? former33t Flooring 3 10-15-2009 01:34 PM
Metal wire staples vs. Plastic wire staples tripower Electrical 14 02-18-2009 05:23 PM
