Insulate & Vapor Barrier Around Electrical Box - Electrical - DIY Chatroom Home Improvement Forum
Old 04-26-2010, 12:57 AM   #1
insulate & vapor barrier around electrical box
exterior walls require insulation & vapor barrier. Electrical boxes on exterior wall breaks the vapor barrier if the box itself is not sealed. How do I maintain a sealed vapor barrier around the box? I've seen vapor barrier wrapped behind the box, but I dont understand where the cables would come in from. The cables will have to also poke a whole through the vapor barrier, so how do you seal that around the cables?
acerunner is offline   Reply With Quote
Old 04-26-2010, 08:44 AM   #2
Rewards Points: 320
I believe they make a plastic box that is nailed to the studs and then the electrical box is installed inside of this. It gets sealed with foam or silicone for the penetrations and the vapor barrier is sealed to the face of the box with silicone.
teamo is offline   Reply With Quote
Old 04-26-2010, 09:14 AM   #3
Just call me Andrew
Rewards Points: 1,020
I had this same question actually. I've seen some stuff that Mike Holmes uses, it's like a rubbery material that is wrapped on the back of the box. Any idea what this is or where to get it? Maybe a supply house would have it.
What about using the foam weather stripping behind the outlet? That would block a fair amount of moisture, right?
Andrew
secutanudu is offline   Reply With Quote
Old 04-26-2010, 01:28 PM   #4
Check your big box stores. I found at one near me a molded plastic (6-8mil) that has flanges incorporated into it. Then you just tape your VB to it.
see pic:
http://images.google.com/imgres?imgu...HcO78gatw6WrDw
baum is offline   Reply With Quote
Old 04-26-2010, 02:22 PM   #5
thanks. I found one such box here: http://www.lessco-airtight.com/
But with that, you would still need to find a way to seal the hole where the wire come through this box. In the picture, looks like they taped it or something. I think a putty or silicone (as you mentioned) would work well here.
Old 04-26-2010, 02:24 PM   #6
Just call me Andrew
They don't sell these at my local big-box store or electrical supply house. I don't have time to order one - think plastic wrap on the backside of the box with the foam underneath the cover plate will suffice?
Andrew
Old 04-26-2010, 02:24 PM   #7
Yeah, I saw that episode. It was like a sheet of putty that he wrapped around it. Sealed right around the wire and everything. That episode was about sound deadening insulation, so I assumed the wrap was for sound deadening, but the same concepts apply to thermal insulation as well.
Old 04-26-2010, 09:32 PM   #8
Registered User
Rewards Points: 526
http://www.buildingscience.com/docum...ecommendations
http://www.ecohomemagazine.com/energ...gy-claims.aspx
Be safe, Gary
How to install new electrical box without attic access gilmores33 Electrical 10 02-14-2010 07:46 PM
Electrical Engineer allowed to do Electrical work? SarahJennifer Electrical 48 09-21-2009 08:15 PM
Slight electrical current in bathroom faucet water + other unusual electrical events story Electrical 9 09-16-2009 10:28 PM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 11:12 AM
Electrical Box near Shower Valve dasajame Electrical 3 07-07-2008 06:46 AM
