Insulate Around Drafty Circuit Breaker Box - Electrical - DIY Chatroom Home Improvement Forum
Old 01-07-2011, 08:46 PM   #1
Insulate around drafty circuit breaker box
I just opened my circuit breaker box while doing some other repairs in my house and noticed cold air from outside getting in. The box is in a room in my finished basement which of course is very cold. I've never messed with a breaker box before both because I've never needed to and because of a fear that I'll touch the wrong thing and end up in the hospital.
So, dear readers, what's the best and above all, safest way to insulate around the breaker box?
JoeyJoeJo is offline   Reply With Quote
Old 01-07-2011, 09:44 PM   #2
Retired from the grind
gregzoll's Avatar
Rewards Points: 5,882
If you are getting cold air in through the feed conduit, you can just spray foam to help seal the hole. Usually you use what is called Monkey ****, which is a white putty to pack in around wires. It is the best option over spray foam, since the putty is non-flammable, and does not deteriorate over time.
Old 01-07-2011, 11:32 PM   #3
liscenced electrician
Rewards Points: 538
don't use spray foam for this application. Monkey or bear **** would be a good solution for inside pipes. Although what i was picturing, from the question, was drafter air coming in through all the tiny hole in the enclosure of the panel. In my opinion, the ONLY solution would be to remove the sheet rock around the panel and insulate with fiberglass insulation the best you can. You don't want any insulation inside the panel
jimmy21 is offline   Reply With Quote
A/C unit keeps throwing circuit breaker MofElPaso HVAC 15 05-03-2010 12:06 PM
Can't get the master circuit breaker properly seated davefoc Electrical 1 03-22-2010 07:17 AM
Circuit breaker question kupalino Electrical 6 12-19-2009 12:35 AM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 06:55 AM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 09:09 PM
