Insufficient Panel Ground - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 10-23-2012, 05:27 PM   #31
Electrician
Rewards Points: 150
Well...
Glennsparky is offline   Reply With Quote
Old 10-23-2012, 05:37 PM   #32
Electrician
Rewards Points: 150
That metal conduit the service conductors are in, if it continues underground for more than ten feet, it could be a legal second electrode. No ground rods would be necessary.
Old 10-23-2012, 05:40 PM   #33
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
No way, it would have to be driven...
The Following User Says Thank You to stickboy1375 For This Useful Post:
Glennsparky (10-23-2012)
Old 10-23-2012, 05:41 PM   #34
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Are you really an electrician?
Old 10-23-2012, 05:49 PM   #35
Electrician
Rewards Points: 150
I passed my test by one point. And I'd put my swimming pool work up against anyone.
Old 10-23-2012, 06:00 PM   #36
E2 Electrician
I do a lot of pools.
Old 10-23-2012, 09:22 PM   #37
Semi-Pro Electro-Geek
I don't recall seeing that "leftover buried conduit electrode" section in Article 250 of the NEC. Mind pointing it out?
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
Evstarr (10-24-2012)
Old 10-25-2012, 05:46 AM   #38
Electrician
Rewards Points: 150
250.52(A)(5)(a), 2008 codebook. "Grounding electrodes of pipe or conduit..." Wise guy.
The Following User Says Thank You to Glennsparky For This Useful Post:
mpoulton (10-25-2012)
Old 10-25-2012, 09:45 AM   #39
Well paint me blue and call me Babe! The "leftover buried conduit electrode" is actually specifically endorsed by the NEC. I'd never heard of that before.
Old 10-25-2012, 10:40 AM   #40
jrclen's Avatar
Rewards Points: 514
Originally Posted by Lemkie View Post
first: This is the main fuse panel for the whole house.
Then: Just to clarify this is the one and only panel for the house. The wires in the picture are the main power wires coming from the street. I realize these stay live if the main breaker is switched off. What I didn't know if it the main breaker being off was enough to move the ground wire
Where is this main breaker you keep mentioning?
John
jrclen is offline   Reply With Quote
Old 10-25-2012, 12:43 PM   #41
k_buz's Avatar
That code does not cover the conduit the service entrance conductors are run thru, and you would still need two.
The Following User Says Thank You to k_buz For This Useful Post:
jrclen (10-25-2012)
new sub panel BlueBSH Electrical 11 01-22-2012 08:28 AM
New detached garage with sub and ground, house has no ground at panel italie Electrical 9 09-12-2011 02:43 PM
Service panel ground downunder Electrical 13 05-13-2011 04:46 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 04:58 PM
Nuetral from feeder cable to main panel question? TW Lucas Electrical 14 05-08-2008 11:33 AM
