Installing Wiring For A Sauna - Electrical - DIY Chatroom Home Improvement Forum
Old 02-03-2009, 09:48 AM   #1
Installing wiring for a sauna
We would like to save some time...
Needed a dedicated 120V 20A Circuit and Outlet. However, we received the wrong user manual and wired the plug (per the old user manual) for a 120V 30A outlet, using 10 g wire... now we find out we only need 20A outlet. Do we need to rewire with 12g wire or can we use the 10g that is already behind the drywall?
tvandlen is offline   Reply With Quote
Old 02-03-2009, 09:56 AM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
The 10 awg (gauge) wire is fine just install a 20 amp breaker and change the receptacle to a 20 amp if needed. Be sure your new receptacle will accept 10 gauge wire. The better receptacles will... don't get a cheapie. Bigger wire is ok but for example 12 awg for a 30 amp branch circuit would be a no no. Any gfci required with the sauna??
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-03-2009, 10:04 AM   #3
Thanks for your help. Glad to hear from you so soon.
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 08:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
Installing new lighting on knob and tube wiring drichard Electrical 1 03-05-2006 02:55 PM
Installing a ceiling fixture Cregan Electrical 3 02-08-2004 09:43 PM
