Installing Wall Sconces - Have Knob & Tube Want To Replace With New Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 09-23-2011, 07:10 PM   #1
Installing wall sconces - have Knob & Tube want to replace with new wiring
How do I install new wall sconces when my old ones were nob and tube and the wiring is soldered
barbarae is offline   Reply With Quote
Old 09-23-2011, 07:51 PM   #2
DIY staff
Rewards Points: 7,174
Post a picture---Should be a mater of cutting the wire in order to attach the new using wire nuts--Mike---
Old 09-24-2011, 04:33 AM   #3
Code05's Avatar
Rewards Points: 1,104
Actually most new fixtures instructions say to attach to 90C wire, so 110.3(B) is a player.
(B) Installation and Use. Listed or labeled equipment
shall be installed and used in accordance with any instructions
included in the listing or labeling
Code05 is offline   Reply With Quote
Old 09-24-2011, 04:37 AM   #4
Code05's Avatar
Working with knob and tubing wire is a project that can south real quick, if you are inexperienced. I would seek out an electrician and let him/her take the responsibility.
The Following 2 Users Say Thank You to Code05 For This Useful Post:
NJMarine (09-24-2011), oh'mike (09-24-2011)
Old 09-24-2011, 09:07 AM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 850
Ditto on that.....
help installing wall and recessed lights. nancyT Electrical 4 09-15-2010 02:58 AM
Wiring for wall sconces in bathroom bigburb Electrical 7 05-20-2009 09:23 PM
Insulating wall when running Copper Tube lines to an exposed wall face scubber Carpentry 5 04-13-2009 11:23 PM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 10:44 PM
Installing new lighting on knob and tube wiring drichard Electrical 1 03-05-2006 03:55 PM
