Installing A Wall Oven - Electrical - DIY Chatroom Home Improvement Forum
Old 10-30-2011, 08:25 PM   #1
Rewards Points: 111
Installing a wall oven
I recently bought a wall oven and am trying to install it.
The armored power cable is not long enough to reach my electrical junction box. My electrical junction box actually still has the armored power cable from the previous oven. Could I safely join the two and still be in spec? Hope I'm making sense as I'm don't have much experience with electricity. Or should I build a new cable that is long enough to reach the junction box?
Thanks ahead. I will try to provide pictures shortly.
suncowiam is offline   Reply With Quote
Old 10-30-2011, 08:40 PM   #2
I=E/R
a7ecorsair's Avatar
The oven you just bought, is it used? You say it has armored cable already attached.
a7ecorsair is offline   Reply With Quote
Old 10-30-2011, 09:10 PM   #3
Rewards Points: 111
it's brand new from sears. kenmore series. it came with a 5-6 foot cable already attached.
Old 10-31-2011, 01:39 AM   #4
Code05's Avatar
Rewards Points: 1,104
Many of the new units have a prewired FMC or MC whip.
Code05 is offline   Reply With Quote
Old 10-31-2011, 01:42 AM   #5
Code05's Avatar
You can add another J-box and join the two cables. Is this 4 wire to 4 wire?
The Following 2 Users Say Thank You to Code05 For This Useful Post:
1910NE (10-31-2011), SD515 (10-31-2011)
Old 10-31-2011, 09:57 AM   #6
Rewards Points: 111
I just saw this video:
http://www.diynetwork.com/videos/ins...deo/47146.html
It suggests the same thing as you, Code. But then it leaves the junction box floating in space behind the oven cabinet through the drywall. My cabinet will not have space for another junction box unless I also cut the drywall and let it float behind the drywall. Is this acceptable?
Yes, it is 4 wire to 4 wire.
Old 10-31-2011, 11:15 AM   #7
Licensed electrician
Rewards Points: 1,634
Normally the instructions will tell you where you can put the junction box to join the house wires with the oven wiring.
The box should not be floating.
Old 10-31-2011, 12:14 PM   #8
Rewards Points: 111
i already have a junction box above the oven cabinet. i just need to securely join the two FMCs. do i really need to secure the new junction box?
Old 10-31-2011, 12:28 PM   #9
Rewards Points: 3,130
Check your new oven's installation instructions. They will tell you where the junction box needs to go so that the oven will slide all the way in. I would not have a "floating" box, nor would I try to join the FMCs.
Old 10-31-2011, 02:32 PM   #10
Rewards Points: 111
I've checked. It says to pull the supplied fmc to the current junction box.
I just don't have enough length at the moment so I'll have to build a 10 foot cord.
I was hoping there was a way to safely secure two fmc's as I do have that to make it reachable and have enough slack for services.
Old 10-31-2011, 03:41 PM   #11
Why would you need a 10 foot whip to wire the oven? Most times you only need 3 foot or so to allow the unit to be slid out to be wired.
Old 10-31-2011, 04:19 PM   #12
Rewards Points: 111
My current junction box is in the cabinet above the oven opening. The new oven's fmc is connected to the bottom of the oven. It is about 5 ft long. The distance to the junction box is about 7 ft long. 7 + 3 foot of slack = 10 total ft...
taking down a wall and installing a new countertop danxp General DIY Discussions 7 10-18-2011 08:03 PM
Installing laminate in a room with one big curved wall (PICS) vu321 Flooring 9 06-04-2010 03:15 PM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
Wall oven rusty_5620 Electrical 6 03-15-2007 01:18 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
