Installing A Wall Mounted Light Without A Gang Box?? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-19-2012, 01:20 PM   #16
Electrical Contractor
jbfan's Avatar
Rewards Points: 490
Originally Posted by blue sky View Post
No problem, I'll use a spade bit for the short hole for the LB to sit flush on one side of the post. One the other side of the post, I'm not using a gang, but a pancake instead. Can I just run the cable through a knockout hole and into the fixture without any clamps?
Nope, it needs a clamp.
The Following User Says Thank You to jbfan For This Useful Post:
blue sky (09-19-2012)
Old 09-19-2012, 01:52 PM   #17
Originally Posted by Oso954 View Post
The box shown has two internal clamps. I'd use one and remove the other one to maximize space in the box.
Does the light you are using have a complete metal backplate ?
If not, you are going to have open gaps on each side of your post (from the backside).
Have you considered how you will close the gaps ?
Thanks. I'll look for a pancake w/clamps and offset knockouts, I hope HD carries them. I will router a recess for the pancake so it sits flush and the light is more narrow than the post, so it will have complete backing.
As for the clamps in the picture you posted, do I simply "loop" the cable under it? I know it's a very basic question, but I've never used these clamps before.
blue sky is offline   Reply With Quote
Old 09-19-2012, 02:09 PM   #18
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Watch the boxfill in the pancake boxes.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 09-19-2012, 02:15 PM   #19
Oso954's Avatar
Rewards Points: 1,126
There should be KO's under the clamps, just not readily visible in the pic.
The site you posted doesn't give the width (or I missed it). Several other sites list the dimensions as "height of 9.5" a width of 7.75" and an extends 3.625" out".
If you have it in hand, you are good. But if you are relying on Amazon's "4 inch width", you might be in for an unpleasant surprise.
Oso954 is offline   Reply With Quote
Old 09-19-2012, 02:29 PM   #20
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,216
Most of those pancake boxes are only 6 Cu in, so basically they will take a single #14/2
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
Old 09-19-2012, 02:39 PM   #21
I'm only running a single 14/2 to the fixture so I'm good.
Old 09-30-2012, 05:14 PM   #22
If you use a pancake box and use the internal clamps it seems they have a 1/4 inch knock out. Do you have to put some kind of plastic bushing or insert so that the sheathed cable is not rubbing up against the 1/4 inch knock out.
buildit45 is offline   Reply With Quote
Old 09-30-2012, 05:33 PM   #23
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
no....
Hitting a Joist when installing a recessed light? hicksjh Electrical 9 11-22-2010 08:27 PM
Need help with how to mount porch light to concrete foundation wall wherm5150 Electrical 7 11-16-2010 08:56 PM
Replacing Bathroom Wall Mounted Light Fixtures Bob1946 Electrical 9 08-06-2010 01:28 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Installing outdoor floodlight - almost no wall access wylker Electrical 4 03-15-2010 12:19 PM
